squeek squeek ???
Old Mar 30, 2007 | 01:25 PM
George Hubert's Avatar
George Hubert
Default squeek squeek ???
In the last week my 98 vert has developed a squeek that sounds like an old farm truck that hasnt been lubed. When I try to make it squeek in the garage by bouncing the car up and down at the corners no sound but when I go over a speed bump at a crawl, or enter a driveway with a steep pitch the squeek is loud enough that occasionally someone looks at my beautiful vette and frowns. Someone told me that it is probably the sway bar bushings??? Any other ideas I just had the car serviced including lube last month. Help!!!
Old Mar 30, 2007 | 01:51 PM
omarcoolguy's Avatar
omarcoolguy
its the bushing on the front......its from cutting the bushing ....did u lower oit....or was it lowerd??.....mine did the same thing i had 2/3 the bushing cut......goodluck......it might help if u put smoe more support between the a arm and the bolt....like a rubber washer...
