Sometimes my turn signals don't want to work, but when I reach over and touch my 4 way flasher button, they begin to work......is this a common issue and is there an easy fix?
Failure of the 4 way flasher unit is a regular problem. The only way to fix it permanently is a new switch. To change it you need to strip down the console. There's a DIY posted when you decide to do the job.
Problems with water ingress into the light units causing bulb failures is also common.
I believe the issue with the 4 way switch is contaminated contacts internal to the switch. Well over a year ago I had the exact same problem. After being in the electronics industry for 38 years I understand the issues with contamination in/on electronic components.
My recommendation is get yourself some electronical contact cleaner (plastic safe) and spray generous amounts directly into the 4 way switch and push the switch 20-25 times. Do ths a few times and I think all will be well. Good luck! Ron
OMG!! I'm SO Glad I ran across this..this VERY problem has been driving me NUTS!!!!! THANK YOU Arauggggh! Finally!! I'll get a switch next week and this little project just got moved to top of the list of things to get done...painting the house can wait!
I've seen posts where thats worked for the turn signal switch on the stalk so its definitely worth a try
I'm curious...is this the only flasher on the C5? I was looking and looking and noticed there is none on either of the fuse blocks...Figures they will go and HIDE it deep inside the dash. Regardless, I'm going in!
