Trailering lowered vette
Old Apr 1, 2007 | 07:30 PM
USRobo's Avatar
USRobo
Default Trailering lowered vette
How are you guys getting your lowered Vettes onto your trailers?
Old Apr 1, 2007 | 07:42 PM
napacruzerc5's Avatar
napacruzerc5
Haven't done it with a C5 but with my '68 racer had extra long ramps. Ramps almost as long as the trailer. Some people also drive up their tow vehicles onto low ramps or blocks of wood so that the rear wheels are higher than the fronts in order to straighten out the trailer-ramp connection.
Old Apr 1, 2007 | 07:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I have a tilted trailer and some 2 x 8's. Just slowly walk in up a stacked set of ramps made from 2 x 8's.
Old Apr 1, 2007 | 08:06 PM
USRobo's Avatar
USRobo
I have a dovetail on my trailer but the ramps are 5 foot long and I place 2x10's on the ramp but it takes two people to put their foot on the wood so that it doesn't move as I drive the car onto the ramp.
I also would like to be able to get the car onto the trailer by myself. Currently it takes minumum two if not three people. I have found that the would slips and if you get caught in the rain the tires tend to slip going up the ramp.
I would like to extend the ramps somehow so they stay in place as I drive up ramp .
Old Apr 1, 2007 | 08:13 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I screw the boards together so that there is a little over-lap so that the top piece sits on the ramp and the bottom piece hits againt the ramp so that they don't slide up.
Old Apr 1, 2007 | 08:17 PM
USRobo's Avatar
USRobo
Now I like that idea! Do you have any pictures?
I can make that from my 2x10's.
Old Apr 1, 2007 | 08:26 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I don't have any pictures, but it is a relatively simple idea, so you should have no problem doing it. Also helps to take along a couple of bungy cords to wrap around them to keep help keep them in place.
Old Apr 3, 2007 | 09:55 PM
USRobo's Avatar
USRobo
Default Solution???
Everyone, thanks for all the input. I currently use a 2x4 to get my car on the trailer ramps but with recent suspension work the car needs to get higher to get onto the ramps. After reviewing everyone’s input I was in Sam’s Club yesterday and saw these ramps that I hope will fix the problem. If this get’s the car up high enough the next issue will be to try to tie them into the trailers ramps so I will have a smooth transition unto the trailer. By the way these ramps are $55 + tax at Sam’s club so it is probably the same cost as making wood ramps and easier to carry around/store.A picture is worth a thousand words so I have included pictures of what I bought and the two ways I can possibly use these ramps to help get onto a trailer.
1st way to try to use ramps
Box
Ramp laid flat out
Flat ramp under car
2nd way to try to use ramps
Ramp double up partially under car
Ramp double up under car – Notice air dam
Ramp double up all the way under car – Air dam bends back
Side view of ramps
The goal is to get the car onto the trailer ramps and trailer without damaging the 1. Paint 2. Air dam
Next I will pull the trailer out and experiment with moving the car onto the trailer. Unfortunately this will have to wait a week or so because as nice as it is today (75 degrees) Tuesday, the temperature will drop to around 35 tomorrow and snow Wednesday night into Thursday and it is suppose to stay cold through the weekend.
Perils of living up north.
Appreciate all your thoughts and inputs on how to help make this work.
USRobo
Old Apr 10, 2007 | 11:19 AM
Brute's Avatar
0Brute
Former Vendor
Well you mite want to look here
I think we have a better idea
Quote:
Originally Posted by davidfarmer View Post
I would be interested in any custome sizes you've done for trailer ramps. I'll likely be running a full splitter on my car soon, and can be very difficult to get into the trailer. 54" might be enough, but more could definitely be better!
Thanks!
Here ya go just got it up
http://www.raceramps.com/store/shopc...sp?type=custom this should work now
This will give you some idea.
Brute
Old Apr 10, 2007 | 11:25 AM
USRobo's Avatar
USRobo
Please update link. It currently does not work.
Custom Ramps? How much? Traveling where do you store them? The fold-up ramps seem easy to store on the trailer?
Looking for all ideas.
Old Apr 10, 2007 | 11:42 AM
Brute's Avatar
0Brute
Former Vendor
Thanks for the heads up, here's the updated one
These are NOT steel and are very light, the surface will not dent, ding or scratch.
You can just lay them down in front of the tires and just put a strap on them our slided them under the car.
The custom ramps are priced by the size, so we would need to know what you would need for you application.
This is our standerd trailer ramp,
http://www.raceramps.com/store/shopexd.asp?id=68
See what you think.
Brute
Old Apr 10, 2007 | 01:29 PM
AU N EGL's Avatar
AU N EGL
Long ramps on a long door. about 12 feet total
Old Apr 10, 2007 | 01:46 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Here is a $15.00 - $20.00 fix that works very well. I took this from a forum member who answered the same question I posted a few months ago. His idea is wonderful. Screw, glue, 2X12 and an hour of your time. Heck Home depot and Lowes will even cut the wood for you.
This gets my lowered coupe onto my 5" ramps and it does not touch anything. Best part is DIRT CHEAP
Old Apr 10, 2007 | 10:36 PM
USRobo's Avatar
USRobo
I like your home made ramps, small and look light. When the weather gets warmer I will try the Sam's Club ramps with wood in front to see how the do and look into making all wood ramps. The 2x12's get expensive and if the fold up ramps work I may only need to put a piece of wood in front.
The race ramps are really nice but expensive.
Old May 10, 2007 | 10:28 AM
nytrydr's Avatar
nytrydr
7th Gear
Thanks for the help, these may be what I'm lookin for or the home made ramps look sweeeet...........
To Trailering lowered vette
