I know some of you will flame me for even considering it, but I am thinking about putting ceramic pads on my 02 Z06 to cut down on the dust/squeaking. It is my 15,000 mile a year daily driver with polished CCWs on it so you can imagine how much time I spend keeping the wheels looking nice. I plan on tracking it when I can get some time and would obviously switch out the ceramics for that. My question is this. How much difference will the ceramics actually make in performance? I know there is some loss in stopping power, but no idea how noticible it actually is. Thanks in advance!
I don't notice any difference in regular to fairly hard braking, but I've never tracked the car, so.... I got the GM ceramics for the front, and rear, but never got around to doing the back ones. %99 of the dusting occurs on the fronts.
No flames from me...I've been using 'em for a while. VERY little to no brake dust. For street use, they are fine. Compared to the OEM pads that were on my '03 Z06, they don't have the same "bite", but will still bring my ride to a stop quickly when needed. I've had NO issues with 'em at all.
I too have 2 different pads (1 for track & the ceramic for street) for my C6Z which seems to be where you're headed. Obviously, the more aggressive pads bite much better, sqeal lot more & make much more dust. The exact opposite of the ceramic material. The main issue IMO aside from the few mentioned above, is that if you track the ceramic pads, they will wear out a lot faster than the more aggressive pads. So if you decide to go this route, DO NOT FORGET to switch when you hit the track. Hope that helps.
I don't think the ceramics will cause you any problems at all. An occasional trip to the track they will still perform very well. Not as good as stock or racing pads but for most people it will not make any difference. Keep the stock ones and after first session on a track day decide if you want to change.
Installed ceramics about 1k miles ago and didn't notice any difference on the street until this weekend when I decided to try a few high speed stops from 125 - 130 mph. Like you I changed them because of the dust, but I should of kept the factory pads and dealt with the dust. I would not recommend them for track use.
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
The stopping power is not noticeable unless you stand on the brakes. Then you'll likely see a 15% difference.
What I did was put ceramics on the front & kept the stock pads on the rear. No codes & almost no dust on either front or rear rims.
When I went road racing I'd just swap back in the stock front pads.
Try it out this way, you won't be disappointed. Don't use the xeramics on a road course though! They're fine for drag racing...
If you're looking for a ceramic pad that has a real bite. The Cobalt GT Sport pads are an option. There is little or no dust since they are made of a ceramic/metalic composite.
I do the same thing. Ceramics for the street / Carbotech racing pads for the track. No problems. You can invoke the ABS with the ceramics, which means you are stopping as hard as the car can stop with the available traction. The only problem would be repeated high speed stopping would eventually induce some fade.
I live in FL so this is not a problem, but the only circumstance that I would not consider this set-up, would be if I lived deep in mountanous territory, and had to go down very long downgrades during spirited driving... in that case I would stay stock.
Just being a 'ceramic' isn't necessarily telling you all that much about a specific compound. It's more of a buzzword than anything right now. The actual ceramic content on various pads is all over the map. That said, it's true that the pads most of the manufacturers put in this classification generally do not have as much bite as some of the more metallic compounds. They won't necessarily degrade your stopping distances, etc. though...so no need to worry.
If you're just going to be cruising around on street with them, I would do it if brake dust is a concern for you.
We sell Hawk Performance Ceramics on our site:
Front C5Z06
63.443.0731 Performance Ceramic - STREET PERFORMANCE $104.00
Rear C5Z06
63.443.0732 Performance Ceramic - STREET PERFORMANCE $72.95 https://www.stoptech.com/user/searchproducts.asp
That makes total sense. The GM pads that I use on the street are called "ceramic" AND the Carbotech Panther Plus and XP8 "race" pads that I use at the roadcourse are ALSO considered "ceramic" (from what I understand).
The good part is that they are both super rotor friendly and completely compatible (no wearing off the "old" coating on the rotors with a lengthy bedding procedure). I switch freely between them. No problems in several years.
I had ceramic for Ax and just recently swap to PFC Z rated....bing difference. I did the swap because I will track the car for the first time on the 28th.
Front C5Z06
Rear C5Z06
I'm ordering these pads now and will give them a try, thanks Jeff.
- Max
