Key in reminder chime disable?
Old Apr 6, 2007 | 11:46 PM
bogspores's Avatar
bogspores
Default Key in reminder chime disable?
I've searched the forum, but haven't found a solution to disable the annoying "key in" chime....
I like to sit inside my car, with the drivers door open, and listen to the radio while messing with my radar detector, GTech or whatever....but the darn reminder chime won't shut up!....
Any solutions for turning it off?....
Old Apr 6, 2007 | 11:48 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Apr 7, 2007 | 01:07 PM
bogspores's Avatar
bogspores
Nobody?....Anybody?....I'm getting worried there may be no easy way to disable the chime....short of cutting wires!...
Old Apr 7, 2007 | 03:29 PM
DeeGee's Avatar
DeeGee
I've asked before and no one came up with a solution
I'm with you. That is the most annoying thing in the world when you're working on the car.
Old Apr 7, 2007 | 03:34 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Turn ignition to the on position, give that a whirl.
Old Apr 7, 2007 | 03:36 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Sorry, cant' help with a wiring fix BUT,,,
Get a Window Valet and use it for extended RAP. Take out the key, hit the unlock three times and the RAP turns on. Listen till your heart's content.
Old Apr 7, 2007 | 03:46 PM
DeeGee's Avatar
DeeGee
Never thought of that. Does it work when the doors open?
Old Apr 7, 2007 | 03:51 PM
bogspores's Avatar
bogspores
Thanks for all the replies and tips!.....
Silly question alert: What is a window valet?...
87SAM's Avatar
87SAM
Funny, I don’t recall mine dinging with just the accessories switch on. In the ignition on position, it rings for a few seconds. Try the reset button?
Old Apr 7, 2007 | 03:55 PM
bogspores's Avatar
bogspores
You're a lucky one if your chime is silent in the accy position with the drivers door open....
I had thought about turning the ign to the "on" position, but figured it wouldn't be good for the battery or fuel pump?....
Old Apr 7, 2007 | 04:16 PM
DeeGee's Avatar
DeeGee
Great gadget if you have a Vert
http://www.topdowntech.com/wvc5Documentation.html
Old Apr 7, 2007 | 05:45 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Originally Posted by DeeGee
I have one but couldn't find my manual in time to post. Window Valet= $149 and a multi functional tool.
Old Apr 7, 2007 | 05:48 PM
Have no idea how to disable the chime, but agree on getting the window valet - great product.
Old Apr 7, 2007 | 09:28 PM
bogspores's Avatar
bogspores
Thanks again for all the great info!....
The WV seems like a great product!....Glad I learned about it!...
Heck, I wish someone would figure out how to program (disable) the chime on the Window Valet....that alone would be worth 50 bucks to me!....
Old Apr 8, 2007 | 02:02 AM
DeeGee's Avatar
DeeGee
Think positive
When you've finished the job and the bonging noise stops, what a big relief.
Old Apr 8, 2007 | 02:10 PM
bogspores's Avatar
bogspores
Heh heh!....yup, I guess that is certainly one way to look at it!....
Old Apr 8, 2007 | 08:23 PM
Cosmic Charlie's Avatar
Cosmic Charlie
Default Fix
ON MY 04 Silverado 2500 HD LT I found a fix.
I use a key or small screwdriver (or anything) to just click the door latch like the door was closed (on the door - not the door jam) and the car / truck thinks the door is closed, BUT remember to pull the door handle before closing the door to reset the catch. Once in a while pulling the handle will only reset the latch about 50 % so check it and make sure it's fully rotated before closing the door.
Works for me ALL the time.
To Key in reminder chime disable?
Old Apr 8, 2007 | 08:27 PM
tsts's Avatar
tsts
Maybe something simple? Find the source of the sound - apply appropriate duct tape?
Old Apr 12, 2007 | 08:24 PM
bogspores's Avatar
bogspores
Hey!...those are both pretty good ideas!....
I've actually "modified" the old style "pin switch" in the door jam before on other vehicles I've owned....but didn't know where the switch was for the vette....So, it's in the door....thanks for the tip!....
I'll try the latch trick tonight!.....thanks!
Old Apr 12, 2007 | 11:32 PM
PierEagle's Avatar
PierEagle
VELLY, VELLY IMPORTANT. Forget and close the door a couple of times without doing this and you'll create some other problems.
