I recently purchased a set of euro taillights (clear style) off ebay. After I installed the lights/wiring harness I noticed when I stepped on the brakes, both the red and clear lenses lit up. Is there any way to rewire the harness so that when I stepped on the brakes only the red lens lit up and was separate from the clear turn signal portion?
Here is what you need to do.
Under the Dash on Drivers side.
1. Pull down on the lower closeout panel push in retainers (just in front of the knee bolster) from the dash lower support beam.
2. Lower the front edge of the closeout panel to expose the brake pedal switch (just to the left of the steering column, at the top of the brake pedal). The switch has a White, an Orange and a Blue wire.
3. Cut the White wire.
4. Re-install the closeout panel (be sure to align the notch in the right front edge of the closeout panel with the tab on the accelerator pedal bracket)
Thanks for the instructions. It's exactly as you indicated. There were instructions that came with the kit, but it didn't indicate anywhere on that sheet that I had to cut a white wire under the dash. Thanks for your input.
