Oil Changing Procedure
Old Apr 11, 2007 | 09:08 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
Originally Posted by Mike98SilVert
Here are some methods:
http://www.c5forum.com/diy/oilchange.php
http://www.97vette.com/howto/oil/index.html
http://www.corvettedreams.com/oil.htm
Lifting without pucks. :
http://www.z06vette.com/diy_lift.php
Other links to recommended lifting & jacking locations. A hydraulic jack should NOT be placed directly under the CENTER of the front cross-member to lift the vehicle:
http://home.earthlink.net/~theadmira...tible/id5.html
http://home.earthlink.net/~theadmira...tible/id2.html
http://www.idavette.net/hib/C5diy/c5diy1.htm
To add to th lifting thing, I used the jack out of my 88 GTA Trans-am. It fits perfectly in the jacking slots. I see them all over the junk yard whenever I go and they can be purchased for a a few $$.
Old Apr 12, 2007 | 12:32 AM
moserbe's Avatar
moserbe
Originally Posted by VettRick
OK. Try it your way. Then lift the rear a hair and see how much more oil comes out.
That's why.
So tell us, how much more does come out?
Old Apr 12, 2007 | 02:38 AM
toxdoc's Avatar
toxdoc
Originally Posted by Vega$Vette
Most Most Important Rule. Put Drain Plug back in before re-filling with Oil.
Agreed on that error. Been there, done that (once, years ago). Messy, a little expensive, and humiliating at best. At worst, catastrophic if you don't catch it. Just a bummer. Like the man said, put the plug back in.
Old Apr 12, 2007 | 04:30 AM
RebelVette's Avatar
RebelVette
I just drive up on a pair of Rhino ramps, jack the back up and slide a couple of jack stands, drain old oil, drink a beer, REPLACE PLUG, change filter, pour in a beer, drink new oil, etc, etc, etc...
Old Apr 12, 2007 | 06:39 AM
photoguy's Avatar
photoguy
Old Apr 12, 2007 | 07:21 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
This is not brain surgery here....It's no different that any other car. Most importantly---safety first. Good luck and congrats...
Old Apr 12, 2007 | 03:07 PM
c3andc5's Avatar
c3andc5
Originally Posted by rws.1
I also prefer to prefer my oil filter with fresh oil and put a bit of fresh oil on the gasket.
Although I've changed the oil many times on several cars throughout my life, I don't profess to be a mechanic. So, help me understand the benefit of pre-filling the oil filter?
Old Apr 12, 2007 | 03:45 PM
DjCritterus
St. Jude Donor '09
It helps get your system primed quicker and means less time parts are rubbing against each other without lubrication. I prefer this method and it only takes a second or two to do.
Think about it, a lot of filters today are being made so that they don't let the oil drain back into the reservoir/pan when the engine isn't running jsut for this reason. Some see it as a gimmick and I see it as something that definitely isn't going to hurt my motor.
Old Apr 12, 2007 | 05:00 PM
berryj's Avatar
berryj
That's why.
I changed my buddies C5 oil a month ago and I did it level. Then I pumped up the rear a bit like everyone said and I was amazed how much more came out. Good advice despite the manual it seems.
Old Apr 12, 2007 | 08:51 PM
VettRick's Avatar
VettRick
I don't know...I didn't measure it.
A couple of cups maybe?
Old Apr 12, 2007 | 09:25 PM
c3andc5's Avatar
c3andc5
Hmmm...try this next time you are under your car. Take a look at the location of the oil filter in relation to the crank case. Now, consider where you add the fresh oil at the top of the head. As the oil travels over the valves and down to the crank case, I wonder if any of those internal engine components are getting lubricated? Back to the location of the oil filter. It stands to reason, does it not, that gravity feeding the same oil to the crank case will likely feed it to the oil filter as well? Also consider the fact that the crank case holds a certain amount of the total 6.5 qts of oil in our LS1s. The engineers were brilliant in that they designed the capacity of the crank case such that oil would flow into the oil filter too.
But, if you're happy with your procedure then that's cool.
Old Apr 12, 2007 | 10:25 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
you too..
Old Apr 13, 2007 | 08:29 AM
  #33
berryj's Avatar
berryj
It's like that HEMI commercial... You're about to find out!
Old Apr 13, 2007 | 12:10 PM
  #34
z06Bigbird's Avatar
z06Bigbird
Originally Posted by Blowtorch
Most important rule: refill with new oil before starting engine!
Exactly.
My boss took his Acura RL to dealership, and they forgot to refill the engine with oil.
His wife picks up car, drives it a couple of miles, and guess what????
Dealer picked up cost of replacement engine, but I always wondered if it was a rebuilt or a new one.
Ed
Old Apr 13, 2007 | 01:32 PM
  #35
DjCritterus
St. Jude Donor '09
I'm happy... and I do it wth every vehicle I own. Not all of them were designed as well as the vette
Old Apr 13, 2007 | 04:39 PM
  #36
2KFRC5's Avatar
2KFRC5
Did not know this. When filling the engine with new oil, how does it get into the filter? I thought the filter was filled from pressure from the oil pump, then to the engine components.
