[Z06] Clutch Slipping.
Old Apr 8, 2007 | 01:43 PM
geterdone's Avatar
geterdone
Default Clutch Slipping.
Clutch is slipping hard on 3rd and 4th gear shifts. Car only has 40k on it, I have read about changing clutch fluid for a sticky clutch but nothing for a slipping clutch. I'm I out of luck or should I give it a shot. Just wondering if it would do any good.
Old Apr 8, 2007 | 02:01 PM
Ranger's Avatar
Ranger
If you are looking for advice rather than suggestions on a new clutch...read on. Otherwise, wait for the new clutch advice.
Step one is clean up your clutch fluid until it is pristine. That would normally take 5-10 repititions of the protocol, costing about $6 and taking about an hour. Time well spent.
Step two is determining whether the clutch is slipping and, if it is, in what circumstances.
The usual test is to go up a steep hill in fifth gear and hammer the throttle. If the clutch is going to slip, it's then. Afterward, sniff the firewall on the drivers side. Smell eau de clutch? On the way to that hill, drive conservatively. No launches, no strong shifts, no WOT.
What you need to rule out is that the 3-4 issue is really the cumulative effect of what you did immediately preceeding that. Like the launch, 1-2, 2-3...all with dirty clutch fluid that hampers the pressure plate from clamping fully on the strong shifts.
Just some thoughts.
Ranger
Old Apr 8, 2007 | 11:48 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
Just some thoughts.
Ranger
I love watching your video's
To Clutch Slipping.
