Vert window coming out
Old Apr 8, 2007 | 02:24 PM
cbruer's Avatar
cbruer
Default Vert window coming out
My "98" c5 rear convertible window is starting to separate from the top on the passenger side. Dealer says the only fix is a new top.
Anyone had this happen and what would be the suggested fix?
thanks
Old Apr 8, 2007 | 04:10 PM
chris308's Avatar
chris308
i would take it somewhere that installs and repairs tops. They probably have a sealant to use on there.
Old Apr 8, 2007 | 04:15 PM
DeeGee's Avatar
DeeGee
One member posted that he'd fixed the problem by running a bead of Perfect Glue 2 (from Home Depot) along where it was separating and then pressing it together with rolls of paper.
Apparently it worked.
Old Apr 8, 2007 | 04:55 PM
rws.1's Avatar
rws.1
others have reported success with JB Weld , RTV
Old Apr 8, 2007 | 06:05 PM
XKR100's Avatar
XKR100
St. Jude Donor '08-'09
Had the problem,glass came all the way out.My bud that owns a custom shop recommended that I call a windshield repairman and they used the windshield adhesive to glue back in and its been perfect for a year and a half.not bad in the Texas sun.Jerry
Old Apr 8, 2007 | 06:07 PM
B-rent's Avatar
B-rent
I went to an upholstery shop and they re-sealed it for $100
Dealer said new top, and glass places wouldnt touch it without putting a new window in.
Old Apr 8, 2007 | 06:16 PM
tikiman's Avatar
tikiman
My black top did the same thing. I figured the heat from the sun did it. So I did a temporary fix with weatherstrip adhesive and ordered a new top. Took advantage of the situation to change to a biege top. My car is torch red and I'm happy with the end result. Also, it stays much cooler in the hot Washington, D.C. summers.
To Vert window coming out
