Differential Question
Old Apr 9, 2007 | 08:55 AM
richieice's Avatar
richieice
Default Differential Question
98 convert A/T 2.73 original gears. I took my car to an incredible vette mechanic because the differential was leaking from the drivers side axle shaft and the seal between the transmission and differential. I had every seal on the differential changed/resealed. 2 months later I see a drop of differential fluid. So I put it up on ramps and on the passengers side coming right down the front of the differential I see this rubber hose hanging down and it is cut on an angle. Looks like a drain hose of some sort. I don't remember seeing it there in the past but it looks like it belongs there because it has a clip, which is held onto the differential under one of the side cover bolts, that holds this hose in place. The fluid is 100% coming out of this hose. Is this hose attached to the vent, what does it do and is it original or did the mechanic add it on? I can't find anything about it in the manual either.
Old Apr 9, 2007 | 07:50 PM
WilliamCall's Avatar
WilliamCall
I checked the 2004 service manual (the only one I have), and there is a transmission vent tube. So your assumption is probably right.
Old Apr 10, 2007 | 01:32 PM
richieice's Avatar
richieice
Thanks for checking into this for me. I guess my next question is if I had my trans fluid changed in Feb and this is the first time this happened... Do I have anything to worry about?
To Differential Question
