Drag Radials
Old Apr 9, 2007 | 08:22 PM
Vette1999Hardtop's Avatar
Vette1999Hardtop
Default Drag Radials
I just bought my first set of B. F. Goodrich drag radials and was wonding how much air to run in the tires. I have 4:10 gears and started out with 30lb but spinning the tires at 2500 rpm was not a problem. Dropped to 28 and the same thing happened, however, from a 20 mph stab it really hooks up great. I don't have a line lock so with the 6-speed I was hoping to get a little better start from a dead stop. I'm also hoping that when I get to the track the conditions of the track will help me out. thanks.
Old Apr 9, 2007 | 11:12 PM
USRobo's Avatar
USRobo
At the track you should test tire pressure between 16 and 24 lbs to see what works best for you. On the street you should run 28-32 lbs.
Old Apr 9, 2007 | 11:34 PM
slayer6x6's Avatar
slayer6x6
How much power are you putting to the wheels?
Old Apr 10, 2007 | 06:38 AM
Vette1999Hardtop
About 330 HP to the rear wheels. All i have is vararam, LS-1 edit, 4:10 gears and headers. thanks
Old Apr 10, 2007 | 09:34 AM
Mike94ZLT1's Avatar
Mike94ZLT1
Hardened axle shaft?
To Drag Radials
