Headlight help...
Old Apr 9, 2007 | 10:56 PM
kris6868's Avatar
kris6868
Default Headlight help...
Is maybe my gear stripped or...?
I changed low and high bulbs..
On driver side i used the manual **** to lower and raise the light to get to screws..
On passenger side i did not touch the ****.. that side works fine..
Driver side is like its off position and will go up and down a few time before it comes to a stop. it will hold the up position with no problem.
Has anyone seen this or know the fix...
id truly appreciate...
Old Apr 10, 2007 | 02:40 AM
DeeGee's Avatar
DeeGee
Are you getting any grinding noises when the light moves. Normally if the gear is stripped it will be noisy.
From what you describe it does sound like a stripped gear. If so, open this thread and run down to the section on Hedalight Gears. It'll tell you all you need to know about replacing the gear:
http://forums.corvetteforum.com/showthread.php?t=984927
