front end "sqeaking"
Old Apr 10, 2007 | 01:41 AM
GK VETTLOVER's Avatar
GK VETTLOVER
Default front end "sqeaking"
when I was driving home tonight when I wiould hit a bump I would hear a sqeak from my front end. What could this be my car is a 98 with only 31k on it? should Corvette's have some grease fitting on them or what? Shocks look ok everything seems normal
Old Apr 10, 2007 | 01:56 AM
DeeGee's Avatar
DeeGee
Apparently its the sway bar bushings that need cleaning and lubricating
I'm sure someone who's done the job will pitch in
Old Apr 10, 2007 | 08:04 AM
That would be my first guess. Try that and see if it helps.
Old Apr 10, 2007 | 08:25 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Apr 10, 2007 | 10:18 AM
GK VETTLOVER
thanks guy I will give it a try. Anyone know what do you use to lube the sway bar brushing with
Old Apr 10, 2007 | 11:56 AM
IAIA's Avatar
IAIA
Mine does the same thing, but only going over the dang speed bumps when I first leave my garage. When things heat up, the squeak/scrunch noise goes away.
Waiting to hear how to lubricate........
Old Apr 10, 2007 | 12:00 PM
mickey_7106's Avatar
mickey_7106
Old Apr 10, 2007 | 12:14 PM
rickko's Avatar
rickko
...Waiting to hear how to lubricate........
Lubricating swaybar bushings isn't a normal maintenance procedure.
That said, if you decide to (I think I'd wait awhile to see if it goes away), remove the bushing bracket bolts and bushings then use a little lithium grease on the inner bushing surface.
There are a lot of threads and posts about changing out swaybars which discuss the bushings. I recommend searching for them using 'sway bar' or 'swaybar'. You should get some tips from them.
Good luck!
..rickko..
To front end "sqeaking"
