Sig help
Old Apr 12, 2007 | 01:25 PM
isracing's Avatar
isracing
Default Sig help
Hey guys, not sure if I'm doing something wrong but I have sig... and it shows up in the preview, but I can't see it in any of my posts. I have show signatures turned on in the options...
can you guys see it?
any admins care to chime in and lend a hand?
thanks
Old Apr 12, 2007 | 01:30 PM
DeeGee's Avatar
DeeGee
Try Edit signature in Control Panel.
If not try a post in the help section
Old Apr 12, 2007 | 01:35 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
thanks
You must select the "Show your signature" check box in the Miscellaneous Options section below the post edit window each time you want your signature to show.
Etiquette is to show your sig once per thread.
Old Apr 12, 2007 | 01:39 PM
wallemon's Avatar
wallemon
thanks
Perhaps you are confusing the signature with an avatar?
Old Apr 12, 2007 | 02:02 PM
isracing's Avatar
isracing
No, I know what the difference is and am a member of other boards where they both work fine. I have a pic for my sig, and it doesn't show up at all. Not even in the first post.
Old Apr 12, 2007 | 02:03 PM
isracing's Avatar
isracing
Bingo! that was it... Do you have to do this for ever post you make? or is a default that will stick when you make new posts.
Old Apr 12, 2007 | 04:03 PM
DeeGee's Avatar
DeeGee
Every time
To Sig help
