Codes Codes and more Codes :-(
Old Apr 13, 2007 | 12:37 PM
MedChoice Tony's Avatar
MedChoice Tony
Default Codes Codes and more Codes :-(
I am just now getting every code on the DIC; Example - power down, shock inop, service vehicle soon, low fuel etc. Also the car will not go passed 81mph!
Is this something that will just go away or a bottle of Techron will cure up? Does this mean $$$ will be going out to the dealership? Never had this issue with 19K on the odometer and it's a manual.
Thanks,
TonyP.
Old Apr 13, 2007 | 01:07 PM
HummelS's Avatar
HummelS
Thanks,
TonyP.
I had that happen on my 2000 coupe - it was caused by a BCM that had gotten wet. The BCM is located in the passenger footwell fusebox. Check for dampness in the footwell.
Old Apr 13, 2007 | 01:14 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
sounds like the BCM (body control module) is fried, or you could possibly have a bad ground or battery issue.
Old Apr 13, 2007 | 01:23 PM
MedChoice Tony
How do I go about changing the BCM? Is this something I can do? The battery is new and their is no dampness in that area?
Thanks,
TonyP.
Old Apr 13, 2007 | 01:35 PM
DeeGee's Avatar
DeeGee
First thing I would do with random messages like that is change the battery.
Old Apr 13, 2007 | 01:50 PM
JH's Avatar
JH
Saw all sorts of strange codes when the battery was close to quittting. Also good counsel to check grounds; very sensitive area on all cars these days, most certainly our C5s. Lots of information in this forum, diagrams and instructions, about cleaning grounds.
Old Apr 13, 2007 | 02:11 PM
MedChoice Tony
Battery is brand spanking new! I will have to search ground cleanings!
TonyP.
To Codes Codes and more Codes :-(
