Halltech Airbridge
Old Apr 13, 2007 | 08:14 PM
mrgil's Avatar
mrgil
Burnout
Default Halltech Airbridge
Anyone know how to alter the air bridge from a Halltech Stinger air filter so the damn thing doesn't rub on the hood liner when the hood is closed?
mrgil
Old Apr 13, 2007 | 08:28 PM
hotwheels57's Avatar
hotwheels57
The after market air bridge that I had for a time did the same thing. You might be able to make adjustments at the bellows to shorten the overall length, allowing the air bridge to sit lower. The other option (I didn't do it) I considered was to apply heat to the ABS plastic and collapse it slightly allowing for more wiggle room.
Old Apr 13, 2007 | 08:29 PM
SpeedUp's Avatar
SpeedUp
Just installed one in my car, interested to see what can be done to help this
Old Apr 13, 2007 | 08:32 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Old Apr 13, 2007 | 08:38 PM
mrgil's Avatar
mrgil
Burnout
Default Yup
Originally Posted by Y2Kvert4me
Yup!
That's what I'm thinking.
How about a bolt on alternative? Just the airbridge the filter is great.
mrgil
Old Apr 13, 2007 | 08:45 PM
ditty22's Avatar
ditty22
Same thing with mine bro
Old Apr 13, 2007 | 08:52 PM
slayer6x6's Avatar
slayer6x6
Old Apr 13, 2007 | 09:02 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
mrgil
Get a heat gun and heat it up. Becareful not to hold in one place very long. Like a second or two. Keep moviing the heat around until it it=s really warm. Wear a pair of gloves and push in on intake on the top and you'll feel it push in.
Just got done doing the same thing.
Old Apr 15, 2007 | 12:12 PM
mrgil's Avatar
mrgil
Burnout
Default Pics
Can you post a pic or 3. I don't want to see it concave on the top that would look fugly
mrgil
Old Apr 15, 2007 | 12:18 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
mrgil
It's raining like crazy outside, so I won't be able to get any pictures today.
It really is not that hard. Just use the palm of your hand and gently heat the upper part of the tube and then press down firmly. The material does not bend that easy. Just increase the pressure until you feel give way a bit. Took me about an hour to get it right.
The pictures really won't tell you anything as it is not noticible to the human eye.
Old Apr 15, 2007 | 12:29 PM
mrgil's Avatar
mrgil
Burnout
Default Airbridge
ajg;
Did it discolor the red halltech logo?
mrgil
Old Apr 15, 2007 | 12:38 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
ajg;
mrgil
No it did not discolor the Halltech Logo. Just keep moving the heat gun around and do not not concentrate it in any one area.
I worked the gun on the sides and a little bit in the center. Puch down firmly as the plastic airbridge is quite rigid.
Old Apr 15, 2007 | 12:42 PM
mrgil's Avatar
mrgil
Burnout
Default Here we go!
Ok, I'm gonna try it, nothing to lose, I can always go buy a K & N
One would think Halltech would do a redesign.
mrgil
To Halltech Airbridge
