Stuck dead battery
Old Apr 14, 2007 | 03:52 PM
doccasel's Avatar
doccasel
Default Stuck dead battery
I went to start my 98 vert today and discovered that not only was the battery dead, but it has seemed to have leaked and is now stuck on the tray. Does anyone have a reasonably easy way to get this out?
Thanks!
Old Apr 14, 2007 | 03:55 PM
jrose7004's Avatar
jrose7004
I don't know for sure but maybe baking soda and water mix?
DBL001's Avatar
DBL001
uh ohh better hope it didn't effect the computer under there
Old Apr 14, 2007 | 03:58 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Get it out of there and check the sticky for more assistance.
Old Apr 14, 2007 | 04:00 PM
BOTYNV1's Avatar
BOTYNV1
The first installment under weights,measures..etc look up soon could pose BIG problems.
Old Apr 14, 2007 | 04:10 PM
DeeGee's Avatar
DeeGee
The first thing to do is pull out the battery and see how much acid has got onto the tray. Just give it a good tug and it'll come free. Then open up the fender liner and check to see if the acid has leaked into the area of the BCM. If not give the whole area of the tray a good washing down with an alkaline solution. Baking soda is a good choice. Hopefully its not got to the wiring otherwise you may start to get strange random electrical problems
Don't tell me it was an AC Delco battery I had one do the same to me on the Camaro. Luckily I caught it before it damaged the car.
You'll then need a new battery. Go for an AGM type, Optima dont leak. A battery mat may be a good idea for the future.
Old Apr 14, 2007 | 04:51 PM
doccasel's Avatar
doccasel
It is an AC Delco...2 years old. Believe me, I've been tugging, and I can't get it yet.
Old Apr 14, 2007 | 04:54 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
You didn't say but did you remove bolt for battery tie down? Just double checking.
Old Apr 14, 2007 | 04:55 PM
Dave1998's Avatar
Dave1998
did you revome the wedge at the bottom front edge of the battery?
I will not move without removing this first
Old Apr 14, 2007 | 05:23 PM
DeeGee's Avatar
DeeGee
Its held down by a 13mm bolt through the hold down bar.
Old Apr 15, 2007 | 07:43 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
Good advice. I think DeeGee means PCM, rather than BCM. Critical to make sure no acid has leaked onto it.
Old Apr 15, 2007 | 12:54 PM
DeeGee's Avatar
DeeGee
Oops:o
I did indeed. Thanks
To Stuck dead battery
