Here are two pictures of a stock height vette going up Rhino ramps w/2x8 piece of wood before the ramp.
You make the call...
..rickko..
If that is how people are getting up on the ramps, I could see how the ramps could get pushed forward. I just wedge the ramps right under the tries and drive up. The plastic side air dams are just fine flexing.
And I don't have any trouble using the black ones. (I've never seen the grey ones.)
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
Originally Posted by RayCE
Just wondering.......why the gray ones, and not the black. ???
Not trying to be a smart a$$
Ray
I think the gray is rated at 12,000lbs and the black at 8,000 but the gray seem to be little wider too. I have a cement step up in the front of my garage that I put wood againts to brace the ramps from moving forward cause my floor is race decking. I can back up on them really easy too for cleaning the rear better. One of my cars is lowered so I do need to use the wood to get up on without scaping.
I picked up two honey-comb patterned rubber mats from the Anderson's general store to put under the RhinoRamps and they don't slip.
