[Z06] 2 Quick questions
Old Apr 19, 2007 | 06:50 PM
SSquid's Avatar
SSquid
Default 2 Quick questions
The little plastic piece under the car... the air dam I guess is what it is called... the middle piece with the springs... is the driver side supposed to be further back then the pass side... cause the driver side on mine is pulled way back and the pass side is flush with the 2 little piece on the sides.... 2nd question... WHERE the hell! do you plug HP tuner into these cars... my TA was right under the dash...
Old Apr 19, 2007 | 07:03 PM
Twil1ght's Avatar
Twil1ght
The air dam should be flush with the rubber sides. The bracket that holds it on is very easily bent. You can remove it and straighten that in 5 minutes or so. The OBDII port is under the dash directly under the steering column.
Old Apr 19, 2007 | 07:28 PM
SSquid's Avatar
SSquid
Ok the odd thing is.... the screw hole into the frame on the Driver side is farther back then the passenger side...?
Old Apr 19, 2007 | 08:12 PM
SSquid's Avatar
SSquid
Ahh I see what you were saying now... I took it off and it was bent to hell! fixed it Thanks buddy
Old Apr 19, 2007 | 09:08 PM
Twil1ght's Avatar
Twil1ght
No sweat... those things bend real easy if the air dam contacts something at speed... expect to do that again at some point the way debris liters the highways... the good news is if it ever gets too beat up to deal with the pieces are very inexpensive.
To 2 Quick questions
