C5 yearly differences link
Old Apr 19, 2007 | 08:22 PM
C5A4TT's Avatar
C5A4TT
Default C5 yearly differences link
I ran across this while looking for something else. Never saw it so I figured Id post it:
C5 Yearly differences in models
1997
• Completely new, redesigned Corvette. Base (FE1) and Z51 (FE3) suspension packages.
• All Z51 cars include: Power Steering Cooler, xx, xx, ??
• 97-00 C5 LS1's produce 345 HP @ 5600 RPM and 350 Ft Lbs of torque @ 4400 RPM.
1998
• Convertible becomes available
• Active Handling becomes available late in year
• The two slots of a 1998 (and possibly late 1997s) curve toward the rear at the bottom. (versus straight down)
1999
• 26# injectors substituted for 28#
• Fuel pump revised to reduce noise
• FRC "Fixed Roof Coupe" aka the hardtop, becomes available. All FRC's are MN6 (6-speed) cars with the Z51 suspension package, and are about 60lbs lighter than coupes.
• HUD introduced
• only one line in driver's side fuel rail cover (no fuel return line?)
• Power telescoping wheel becomes an option
• ? Steering hardware changed to combat wandering
• door sill trim plates added
2000
• Millennium Yellow available
• ? "Thin Spoke" versus "wagon wheel" design wheels become standard.
• Pup cats added to CA models for LEV emissions requirements (5hp loss relative to 97-99)
• Steel swaybar endlinks instead of plastic on Z51 equipped cars
• Z51 swaybar diameters grow (25.4/21.7 to 28.6/21.7 to 28.6/23.6 (note: new rear same as Z06)
• No keyhole on passenger side doorhandle
• Passenger airbag 'off' switch added to console (light by TC/AH button)
2001
• return to 28# injectors for all models.
• Second Generation Active Handling
• Nassau Blue discontinued
• Alternator 'clutch' pulley added on A4 cars
• New soundproofing + foam in all cars
• Smaller keyfob
• electrochromic dimming rearview and driver's mirrors
• lighter AGM battery
• Thickness + Material in vert change
• Chrome exhaust tips for coupe + vert
• 85MM MAF with integral temp sensor (versus 74mm with separate plug for IAT)
• LS1 cam profile changed to: .500/0.500, 198/208 on 115.5LSA (From: 0.472/0.479, 202/210 on 117)
• All Corvettes now have the LS6 intake manifold
• All Corvettes now have the LS6 engine block (windage passages in block), which includes a beefier oil pump.
• LS1 changes result in new output of 350 HP @ 5200 RPM and 375 Ft Lbs of torque @ 4400 RPM (MN6)
• Hardtop/FRC discontinued
• Pup cats added to all models
• Stronger synchros in all transmissions
• Exhaust manifolds revised (5hp regained) - thin wall cast replacing SS manifolds
• metal valvestem caps (late year)
• Torque Tube changed from metal-matrix composite to aluminum alloy 6061, increased in dia from 55 to 63 mm.
• Driveshaft couplings have also been upgraded on manual-equipped models for additional strength and durability
• Introduction of the Z06, which has as differences:
o hardtop body style
o rear brake ducting
o screened inlets on front fascia, without foglights
o F1 supercar tires 265-17 front, 295-18 rear, on 17x9.5 and 18x10.5 (one inch wider, respectively
o new LS6 top-end with new style head design (10.5:1 compression, 64cc chamber), LS6 cam (0.525/0.525, 204/211 on 116) - 385hp
o M12 transmission with shorter gearing (1-2-3 analagous to MN6 with 3.90 rear diff
o Titanium exhaust system
o lightweight windshield
o New, stronger clutch with redesigned master + slave cylinder
o Stronger rear differential (shotpeened ring gear)
o Red brake calipers (otherwise identical)
o Trans overtemp warning light on DIC
o 6500 redline gauges with special checkering + Z06 font
o redesigned PCV system to help combat oil burning
o Red LS6 Fuel Rail Covers (FRC's)
o FE4 Z06 suspension - uprated springs, bars (30mm/23.6mm), shocks (note front spring and rear bar same as Z51)
2002
• Z06 Changes:
o Z06 LS6 cam changed to: 0.551/0.547, 204/218 on 117.5
o Less restrictive intake airbox lid
o Descreened MAF
o Removal of pup-cats (total with changes = 405hp)
o Z06 shocks revised with less rebound for better launching
o Z06 brake pads revised for better stopping (generate more dust)
o Lighter, sodium filled valves w/ stronger valvesprings
o higher tension rings installed to prevent oil burning problems
o slight piston redesign *
o clutch strength upgraded.
o HUD available on Z06 (not avail '01 model year)
o Wheel supplier changed to Speedline, moved from forged to cast. Weight nearly identical
• Electron Blue color offered
• Steel endlinks changed to aluminum
2003
• Late model-year new fuel system design from C6's
2004 · Z06 shocks further refined. Accompanying upper front control arm bushing, and rear swaybar bushing changes.
source:
http://www.eliteengineeringusa.com/C..._in_models.pdf
Old Apr 19, 2007 | 08:29 PM
zTrek's Avatar
zTrek
Great post, thanks!
Old Apr 19, 2007 | 08:34 PM
2KFRC5's Avatar
2KFRC5
2000
source:
I thought the cam change for the 2000 year made up for that 5hp difference.
My rears are plastic.
Added mid-year in Feb, 2000.
Old Apr 19, 2007 | 08:40 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Old Apr 19, 2007 | 08:49 PM
C5A4TT's Avatar
C5A4TT
2000 didnt get a cam change according to this and the Corvette Action Center website. No "seagreen" either..
Old Apr 19, 2007 | 08:51 PM
GoForBroke's Avatar
GoForBroke
Great post Thanks
Old Apr 19, 2007 | 08:54 PM
0JPM@AutoBuffs
Former Vendor
http://forums.corvetteforum.com/show....php?t=1673207
2001 was the 5 hp gain
Old Apr 19, 2007 | 09:55 PM
2KFRC5's Avatar
2KFRC5
Yes it did...........................
Old Apr 19, 2007 | 10:10 PM
blkchipC5's Avatar
blkchipC5
Old Apr 19, 2007 | 11:02 PM
stormydog's Avatar
stormydog
Thanks , been looking for this !!!
Old Apr 20, 2007 | 01:24 AM
2KFRC5's Avatar
2KFRC5
2001
• Smaller keyfob
source:
This is the 2000 cam.
Old Apr 20, 2007 | 04:59 PM
C5A4TT's Avatar
C5A4TT
I see numerous places that verify your posts...take this site I posted and the Corvette Action Center site for what their worth I guess. I wasnt trying to argue with you. thanks
Old Apr 20, 2007 | 05:22 PM
2KFRC5's Avatar
2KFRC5
Oh, nor I with you. I was just trying to correct a couple of items of which I was aware. I realize that you were quoting from a couple of trusted sites.
To C5 yearly differences link
