Need help with homelink mod
Old Apr 21, 2007 | 06:56 PM
rkort's Avatar
rkort
Default Need help with homelink mod
Will I did the home link mod to the sun visor, mounted the homelink tho the visor, hook it up to a power source and everything work, then I install the visor in the car and the vanity light work, but the homelink doesn’t, remove the visor from the car and test again with the power source, and both vanity light and homelink and the work, any suggestion.
thanks
Old Apr 21, 2007 | 07:01 PM
Z064life's Avatar
Z064life
St. Jude Donor '06
engrish please...
I have no idea what you just said...so I'll until you explain better
Old Apr 21, 2007 | 07:03 PM
dndrsn's Avatar
dndrsn
Your polarity may be reversed. Won't make any difference with the vanity light but it will with the homelink.
Old Apr 21, 2007 | 07:10 PM
rkort's Avatar
rkort
how would i test for that, if i don't reply forgive me, playing poker tonight start at seven , i am using a freight harbor battery charger for the source.
thanks,
Old Apr 21, 2007 | 08:10 PM
BanditDude's Avatar
BanditDude
thanks,
Make some jumpers from spare wire and reverse the feed between the plugs when sitting in the car. You'll probably need a spare set of hands, though.
I was fortunate enough to test for this before sewing it shut. The pictorial instructions I found online led me to wire it backwards.
Old Apr 21, 2007 | 09:38 PM
C5naples's Avatar
C5naples
Did you get a new homelink or get one from a junkyard? Some of the earlier homelinks will not work on the newest doors with roaming codes.
Old Apr 21, 2007 | 09:59 PM
convertible lover's Avatar
convertible lover
I agree, I had the same trouble with mine. It took me several tries to make it work because I also fallowed the online directions and hooked it up back wards. try reversing the polarity it should work.
Old Feb 5, 2008 | 05:03 PM
carpecervisi's Avatar
carpecervisi
I wanted to bump this because it saved me today. I followed the instructions posted here: http://www.digitalcorvettes.com/foru...ad.php?t=40470
While that was a very nice pictoral, the polarity of it was completely ***-backwards. This is a very easy and cheap mod to do...just do it right.
Thanks to all.
-chad
To Need help with homelink mod
