I installed this on my 03 Z06... for starters it was a PIA to install... 2nd... I am throwing code P0102 and the engine at first didnt want to idle for like 2 seconds when it started up... then I got the code... so I took it out to see how it felt and it feels sorta bogged down a little? it doesnt even spin a tire at all all through first when once the power band kicked in stock it would squeel a bit... and if I quickly tap the gas you hear the huge suck of air... then the rpms shoot up... like a half a second after... you would think it would rise as you hit the pedal... any info?
The Honker shouldn't have been that difficult to install. What problems did you have? They have above average instructions. First you should check that you don't have any major air leaks. It partly sounds like that could be one of your problems. Secondly, it also seems like there might be a problem with the MAF. Is it installed correctly and the plug attached properly. Is it possible you damaged the wires inside the MAF? I had no problems installing mine and it has run perfectly since I installed it over a year ago. It has never caused a code. You really need to reevaluate your installation.
I never took the wires off the maf... nor did I hit the wires on the inside... simply for you to have to remove and cut out the shroud is retarded... then rivet the whole thing.... now after I installed it all it ran choked and ran like I have 250hp running through it... pathetic... I will never own another callaway product again..
We're very disappointed to hear about your situation. If you'd like, you can call us and speak with a technician or an engineer about your installation. There's probably an easy solution to the problem.
One of our factory test cars was a 2003 Z06 and we're very familiar with the application. Honker installation should not trigger trouble codes. There's about 20 hp to be gained with an otherwise-stock '03 Z06. More as soon as you add other performance parts.
Let us help you fix the problem. Please call us at 860-434-9002, 8am - 5pm, eastern US time, Mon - Fri.
Your problem is NOT with the intake, its your MAF. Apparently you did not look up the code. Its P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency. This was not caused by the intake. Callaway builds some of the highest quality products to be found. Once you fix your problem I will bet you will change your "tune" about them.
well before I removed my MAF my car was running just fine... now that I switched everything to stock and it is still has that huge lack of power... any suggestions? and I am still gettin the check engine code with the stock setup
It's obviously something wrong with the MAF - that is what you need to troubleshoot. I have the honker and it's by far the best aftermarket intake for these cars...
yeah I will see what I can do about some pics... I might just trade this for a blackwing since its pretty much a cake walk to install for starters...
You are moving in the wrong direction with the blackwing. Do some research on it. You should take the Callaway offer to help you with technical assistance. Also a piece of free advice do not slam people or products until all of the facts are in
This post refutes your own previous comments knocking the Callaway products. Obviously, if you reinstalled the stock system and it's still running poorly, then that indicates that the intake is not your problem. You have a problem with the MAF or the wiring leading to it. Putting on a Blackwing is not going to solve your problem, especially since returning to stock accomplished nothing.
When I was deciding on an intake I checked them all and the Callaway unit is by far the highest quality and gives some of the best results. Until you resolve your problem you shouldn't bash the Honker until you know the cure. I'm sure that once you get your car running correctly you will feel the satisfaction of purchasing the Callaway. You made a good choice, you just have a different issue to correct.
Maybe I missed something, but how did you go back to stock after having the honker installed? Did you have a spare un-cut shroud or did you rip the rivets loose and now have a gaping hole?
....SSquid has already posted to trade the Honker for a Blackwing in the C5 parts for sale section. Loads of excellent advice has been given here and it seems to have been ignored. Code thrown by the car says it is a MAF problem. People with CAI experience have posted that the problem is a MAF problem and will not be solved by trading for a Blackwing. The manufaturere of the Honker offers to help. What more could someone ask for? I have to ask why SSquid even posted here in the first place?
Jeff
