Fog Light replacement
Old Apr 22, 2007 | 01:11 PM
I dream of vettes's Avatar
I dream of vettes
Default Fog Light replacement
Hello everybody. I just noticed the passenger side fog light is out, and I was wondering what was the easiest way to change out this bulb? Thanks
Brian
Old Apr 22, 2007 | 04:40 PM
jdmvette's Avatar
jdmvette
Night Owl for life
raise the headlamp door and remove the black bezel surround.
reach down and twist out the bulb from the housing.
unplug the bulb from the harness.
replace as needed.
Old Apr 22, 2007 | 08:32 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
replace as needed.
Easier said than done.
Do through the bottom access and replace with Piaa's
Old Apr 22, 2007 | 08:57 PM
If your arms will fit, go through the headlight area by taking the bezel off like mentioned above. Otherwise, take the access panel off under the front fascia and you have easy access to that area.
Old Apr 22, 2007 | 09:31 PM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
Listen to Jason (jdmvette). It's really not that hard. I am 5'11", 200 lbs, and I had no problem reaching down to replace the fogs using his instructions. And skip the Piaa's, if your fog light is out, that means you have the factory fogs already. Save you some money and get the HID fogs instead of Piaa's, you won't regret it, do a search on "HID FOG" thread made by Jason (jdmvette).
I am using the HID fogs from the Ebay guy that Jason mentioned. I don't think Piaa's is this bright and saved me half of the cost of Piaa's.
Andy
P.S. Jason, I swear I am not a stalker
Old Apr 22, 2007 | 10:32 PM
I dream of vettes
Thanks for the help!
Old Apr 22, 2007 | 10:55 PM
jdmvette's Avatar
jdmvette
Night Owl for life
no worries Andy!
Old Apr 23, 2007 | 07:01 AM
meangreen2000's Avatar
meangreen2000
Default arms
as long as you don't have massive forarms. You can raise your head lights. You dont necessarily have to remove the head lamp bezzle. Unscrew the bumper buffers and reach in. YOu should be able to reach it. I'm 6ft and have pretty decent size forearms and was able to do it this way with only minor scrapes and scratches. just go in through the side and under the headlight. you only have to reach about 7 or 8 inches in.
good luck
Old Apr 23, 2007 | 07:28 AM
vet4me's Avatar
vet4me
It took me 20 minutes to replace mine,sliding my hand down along side the headlight.The dealer wanted $90 labor to do the same thing!!!!!!
Old Apr 23, 2007 | 09:43 AM
HollywoodFRC's Avatar
HollywoodFRC
Default Even more room if you need it!
Raise the headlights manually, remove the bezel (three phillips screws), remove the painted headlight cover (two side bolts, and two torx screws on back), then lower lower headlights flat manually. More than enough room, even the 'Fridge' could get his hands on the bulb connector/base. 15 minutes tops per light. Can even unbolt and remove the fogs from the top this way using a little creative twisting and turning. Real easy and roomy. No knuckle busting. Reassemble, lower and check out.
Old Apr 23, 2007 | 09:50 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You can also remove the triangle piece under the Vette right below the fog light!
It has about 6 screws on it and will drop down easily, it will be right above the brake duct, you can move it too the side and replace as desired!
Thanks,Matt
Old Apr 23, 2007 | 03:36 PM
seering's Avatar
seering
I believe you could get to it through to front brake ducts as well?
Least i think i remeber reading that.
Thats how i replaced the side marker and turn signal the other day.
took about 2 minutes and no tools.
The brake duct just slid back and over out of the way .. and i could get enough arm in to disconnect and bring the plugs about 4 inchs out of the front of the hole...
Not sure if the fog light wires are long enough but it saved a ton of skin on my arm from top method headlights... and didnt require laying down to take the bottom off.
Old Apr 23, 2007 | 03:52 PM
Humy's Avatar
Humy
definately not one of those jobs to do while downing one too many brews
I almost split my head open on the hood trying to look down in there and then raising my head too fast
To Fog Light replacement
