Diagnostics codes?
Old Apr 22, 2007 | 05:12 PM
77Stingray99's Avatar
77Stingray99
Default Diagnostics codes?
I was just wondering if anyone knows what this code means. Of if anyone can show me where to find out what it means.
It is: 10-PCM P0442 . Thanks
Old Apr 22, 2007 | 05:13 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
It means your gas cap is open or you have an evap leak...
Peace
Chip
__________________
..................Click for
Old Apr 22, 2007 | 08:36 PM
~Maverick's Avatar
~Maverick
All Men Die, but Few LIVE
Cruise-In IX Veteran
St. Jude Donor '08-'09
Here is a listing of 'most', but NOT 'all' of the codes...This should help you alot...
www.stengel.net/diccodes.htm
It also tells you how to check the codes at the beginning if you are new to that as well..
~Maverick
Old Apr 23, 2007 | 06:26 AM
77Stingray99
Thanks for the advice but I allready asked my wife whether she had the gas cap on all the way and that was not it. So Im not really sure what it is. I also checked that website that you showed me for all the codes but I cannot access it bc I am deployed right now. But thanks again for the help I will just tell her to erase the code and wait to see when it comes up again.
Old Apr 23, 2007 | 10:47 AM
SilvaDragon's Avatar
SilvaDragon
There is a vent in the gas cap. It's supposed to prevent vapor from
escaping, but let air in to prevent a buildup of vacuum in the tank.
These valves can leak, and set this code.
Any gas station that does emissions tests has a device to test the
valve in the gas cap. If your state doesn't test, then I guess that
doesn't help.
If the cap tests bad, or if the code keeps coming back and you
can't easily get the cap tested, go ahead and replace it.
Old Apr 23, 2007 | 10:55 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
details on that code are here - http://www.gearchatter.com/viewtopic10340.php
To Diagnostics codes?
