Antenna won't lower
Old Apr 23, 2007 | 02:07 PM
hauins's Avatar
hauins
Default Antenna won't lower
I was out cruzin this weekend and when I got back to the garage I was wiping the car off before covering it and I noticed the antenna was still up. I went to the ignition key, turned it on, had the radio playing, turned off the key and removed it and the antenna is still up even after opening the door and killing the radio. Couldn't find anything in owners manual on it. Thought someone on forum might know something. C5 is a 2000 with only 19000 miles.
Old Apr 23, 2007 | 02:13 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
I would put the key in the accessory mode, turn on the radio, and see if you can hear the motor for the antenna. Then turn off the radio and see if you can hear the motor again.
If you can't hear the motor, I would check the fuses or check to see if there is a kill switch for the antenna.
If you can hear the motor, then I would try applying some WD 40 or other lubricant to the antenna shaft.
Good luck.
Old Apr 23, 2007 | 04:04 PM
hauins's Avatar
hauins
Never heard of a kill switch for the antenna?
Old Apr 23, 2007 | 04:27 PM
Classic-Chevy-Guy
My error. Kill switch only keeps the antenna down, not up.
Are you getting the motor sound, or not?
Old Apr 24, 2007 | 09:07 AM
hauins's Avatar
hauins
No motor sound.
Old Apr 24, 2007 | 04:17 PM
Classic-Chevy-Guy
You might want to check fuses.
Looks like Fuse 24 is a separate fuse for the Antenna
Last edited by Classic-Chevy-Guy; Apr 24, 2007 at 04:33 PM. Reason: Found specific fuse
Old Apr 26, 2007 | 01:20 PM
hauins's Avatar
hauins
I checked fuse 24 and it was good. I do hear a light humming noise then a click when I turn radio on or off with key on. I WD40'd mast with no help. Sounds like motor may be OK, but something is broke on raising mast. I tried to go thru trunk to see if I could find antenna motor but to no avail. My next move is to lift car and see what can be found from underneath. Anyone know how to get to antenna motor. THANKs
Old Aug 27, 2007 | 01:58 PM
bighank's Avatar
bighank
Default go to antennamastsrus.com for a new OEM mast.
It costs $13.50 plus $6.00 shipping. Instructions on the website. You will have to remove the rightmost tail lens and get to the cap covering the gears after removing thr mounting bolts to remove the plastic cable broken off in the motor. Not hard. Call them up if you need any more guidance. Very knowledgeable. DON'T BUY A NEW MOTOR if yours is running now. $20 not $100 BIGHANK
Old Aug 27, 2007 | 02:48 PM
AC54ME's Avatar
AC54ME
CI 6-7-8-9 Veteran
CI-VI Car Show Winner
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Here you go:
http://forums.corvetteforum.com/show....php?t=1782626
http://forums.corvetteforum.com/show....php?t=1758777
Old Aug 27, 2007 | 03:33 PM
BowtieDiva70's Avatar
BowtieDiva70
I seem to be having the same problem!
Old Aug 27, 2007 | 03:41 PM
DeeGee's Avatar
DeeGee
It's a really easy fix Daphne.
If the internals haven't broken up its a 10 minute job and you don't need to disturb the antenna motor.
To Antenna won't lower
