Removing front fenderwell...
Old Apr 23, 2007 | 02:36 PM
Sixxcat1's Avatar
Sixxcat1
Default Removing front fenderwell...
Is it pretty easy to do? I just pulled my AC Delco after a couple of slow cranking starts and discovered it was leaking. I took care of what I could, but it looks like it goes down and back on the frame a little farther then I can reach.
Thanks.
Old Apr 23, 2007 | 02:44 PM
Scatterbrained's Avatar
Scatterbrained
Default inner fender well
I wouldn't. I would get everything I could without removing the fender well. By the way, the inner fender wells (inner wheelhouses) are secured to the frame and body structure by only a few bolts, but a lot of adhesive. I'm not sure you could get them off intact without doing some damage. Ask me how I know...
S
Old Apr 23, 2007 | 03:03 PM
Sixxcat1's Avatar
Sixxcat1
Thanks for the help. I was actually going to lift it today and see what I could do. Now I'm not.
Thanks again.
Old Apr 23, 2007 | 06:30 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thanks again.
The cavity behind the fender is empty. Just get a hose and some baking soda. Mix up a batch and pour it over to neutralize acid and rinse off.
Did the same thing to my brother's FRC a few weeks back.
Old Apr 28, 2007 | 03:42 AM
Sixxcat1's Avatar
Sixxcat1
Old Apr 28, 2007 | 06:50 AM
DeeGee's Avatar
DeeGee
The plastic fenderwell liner comes out quite easily. There are about 8 or 9 screws/bolts that hold it in. You can see the PCM once you get the liner out.
I've had it out a couple of times when I fitted my AVIC N1. Its easier with the wheel off.
To Removing front fenderwell...
