[Z06] **** Knob Replacement
Old Apr 23, 2007 | 05:56 PM
KBRVETTE93's Avatar
KBRVETTE93
Default **** **** Replacement
What is the best method to remove my OEM shift ****? I believe that I'd like to use an old school "T" ****. Thanks!
Old Apr 23, 2007 | 07:10 PM
jbauch357's Avatar
jbauch357
I decided that explaining this is way harder than showing how in video - next time my buddy is around with his 97 I will make a quick clip showing the vice grips and screwdriver method.
Just remember, if you hit yourself in the head or break the rear view mirror you are working way too hard...
but for now here is one of the many threads: http://forums.corvetteforum.com/show...hlight=pirated
Old Apr 23, 2007 | 09:03 PM
KBRVETTE93's Avatar
KBRVETTE93
Thanks. You're awesome!
Old Apr 23, 2007 | 10:12 PM
zo6makes3's Avatar
zo6makes3
I tried the needle-nose vice grip and two screwdriver method just didn't work. Instead I used a small screwdriver type nail puller and just worked it for what seemed like forever. I could see it moving though, so kept going. You do have to be careful when it gets loose because when it's finally ready, believe me it comes out fast.
Old Apr 24, 2007 | 11:27 AM
z06Bigbird's Avatar
z06Bigbird
Old pipe wrench?? NO!!! Just kidding.
Old Apr 27, 2007 | 12:46 PM
distinctz06's Avatar
distinctz06
drill... screw... slide hammer. works every time haha I broke the top off my demon key with the pressure plier method so this was the last resort.
Old May 29, 2007 | 10:39 AM
KBRVETTE93's Avatar
KBRVETTE93
Got It!
To **** Knob Replacement
