I'd reccomend a ported TB if you're going to go with the LS6 manifold. The TPIS 75x90mm TB with the LS6 showed a 20+ Hp increase over the stock LS1/75mm round combo. Also while the LS6 combo showed a torque increase of ~13 Ft/Lbs, it was a little later in the RPM range. The LS6 intake works best when coupled with an aftermarket Cam.
12 rear wheel might def be work 300 bucks. Any others? I been debating this awhile will be last mod for the car
Sorry, but you'll never FEEL 12 rwhp. However, if you're ever thinking about heads and cam or forced induction, you're going to need the extra capacity. I'd only spend the money if I can bigger plans in mind.
The Intake is only as good as the engine it's attached too. An LSX intake has a larger capacity for HP, but it won't show a noticable difference without heads/cam etc.
Imagine an intake manifold like a link in a chain. You can't pull any more than the rest of the links can take without the chain breaking.
I agree. You've got the exhaust and an intake will give you more on the front but without heads/cam, you're never going to get much out of the change. It would be like an hourglass. Big on top, big on bottom and a big restriction in the middle.
As i've said before im only 21 and i do not have 6k to shell out for a H/C package anytime soon. I just wanna try and get the most out of what i have now.
Why would you want to buy a product that locks you into only one stage of performance? If he buys the LSX intake he can Add heads/cam/intake later. If he doesn't, no harm no foul. But if he does...guess he's gunna be buying ANOTHER intake manifold if he gets the LS6.
I'd rather buy once and do it right. That's just me tho.
When you get into the engine, the chain is very long and every link important. I'd advise upgrading the weakest parts of the chain first, since you have the exhaust and intake covered, you're next 2 thigs to address would be fuel and spark. Spark really isn't too important until you get to high compression, forced induction or N02.
I've heard of guys in the tech section upgrading only the valve springs and rockers, then a cam, then heads. If you're going to do all these things seperatly, you should avoid an agressive cam and make sure you do the valve springs and rockers first (keeping in mind your cam choice). Heads are cool, but along the expensive side of performance parts. You may find that you like the power you get with a cam and the option will always be open for Aftermarket heads. Or you might decide to move to another part of the drivetrain before getting back to the engine.
If it were my $$, i would definatly get the LS6 manifold, but I would probably wait until after at least a cam.
He can get a used LS6 Intake for $300. Use it until he wants to do more mods. If the mods down the road include a new intake then he can sell the used LS6 for $300. So he's really just borrowing it if he goes for something different later.
BTW I have a few mods. At the time I did the H/C, Headers the collective opinion was that the FAST intake was a minimal improvement over the LS6 and NOT worth the $$.
I agree LS6 has proven HP gains and can be sold for the same or more when upgrading even in a year or two people will still be buying them.
