[Z06] Coolant Temp. Gauges?
Old Apr 24, 2007 | 08:18 PM
xiongb1's Avatar
xiongb1
Default Coolant Temp. Gauges?
I was wandering what temp. you guys are seeing on your Z06??
On the freeway my coolant temp. is right around 187 "F
On heavy stop and go, I get around 230 "F and then gruadually dropped back down to 227" F or so.
Old Apr 24, 2007 | 11:04 PM
81c3's Avatar
81c3
Mine is around 188-192 on the freeway, 194 in regular in town driving & can get to 220 in stop & go traffic.
Old Apr 25, 2007 | 09:47 AM
xiongb1's Avatar
xiongb1
sounds right about like mine then.
Old Apr 25, 2007 | 11:12 AM
socal guy's Avatar
socal guy
your temps are normal.
185-195 on highway.
195-215 in town.
Old Apr 25, 2007 | 12:06 PM
RFS-Z06's Avatar
RFS-Z06
Old Apr 25, 2007 | 02:57 PM
Zenak's Avatar
Zenak
Terminal Vette Addict
its normal. if you get worried aobut heat, flush fill the radiator, clean the air filter, clean the radiator of debris... make sure your fog openeings are free and clear.
if you stay under 240 in teh coolant you are ok.. your oil temps arent that high though right?
Old Apr 25, 2007 | 09:48 PM
xiongb1's Avatar
xiongb1
I haven't check. I think 130? not sure whether that was pressure of temps.
Old Apr 26, 2007 | 09:53 AM
Zenak's Avatar
Zenak
after runing for a bit on the hiway you should be atleast 190 in oil temps. theses engines are designed to run and after reading several forum posting about 190 to 210 oil on the DIC optimal... it seems high compared to other cars but hey dude its a Vette :-P
To Coolant Temp. Gauges?
