Part fell off
Apr 25, 2007 | 03:18 PM
Apr 25, 2007 | 03:23 PM
might just be me but i can't see the pics
Apr 25, 2007 | 03:24 PM
here either, couple of red X's
Apr 25, 2007 | 03:29 PM
St. Jude Donor '07-'08
Apr 25, 2007 | 04:11 PM
Oh that thing? Here's what you do.
I cant see the pics so you cant see my advice. Show me yours and I'll show you mine.
Apr 25, 2007 | 04:14 PM
Haven't done the Red
X mod to my Vert
Apr 25, 2007 | 04:19 PM
Apr 25, 2007 | 04:20 PM
You have some major problems if those red X's fall out.
Apr 25, 2007 | 04:21 PM
Quote:
Originally Posted by
Warnberg
Apr 25, 2007 | 04:35 PM
Why that's a red x pipe!
Apr 25, 2007 | 04:49 PM
You guys are lucky .... I can't even see any red X's.
Its the anti pop and backfire valve..... thank god mine has never bottomed out!
Apr 25, 2007 | 05:17 PM
i preveiwed the post and it showed the pics my bad
Apr 25, 2007 | 05:20 PM
Apr 25, 2007 | 05:49 PM
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
Apr 25, 2007 | 06:54 PM
Cruise-In VIII Veteran
St. Jude Donor '07
Looks like the air pump to me.
Apr 25, 2007 | 07:22 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
mph1972
Apr 25, 2007 | 07:33 PM
i say turbo, but thats what i call the AIR pump... but im not sure what it actually does
Apr 25, 2007 | 07:54 PM
Air Injection Reation pump or AIR pump for short is what blows fresh air into you exhaust during the first minutes of cold starting to help light off the cats sooner to keep emissions down. Without that in place, uncontrolled fresh air is getting sucked into the exhaust manifold causing it to backfire. You need to reinstall it or block off the AIR ports in the driver and passenger-side exhaust manifolds and delete it from the PCM using tuning SW or have a local tuner do it for you.
Easiest, most prudent thing to do is have the dealer reinstall it for you. It goes just behind the front fascia on the driver's side.
Your frammitz is shot and the Lincoln bar is bent. Happened to me once.
