Push button start
Old Apr 27, 2007 | 12:54 PM
Vette-kid's Avatar
Vette-kid
Seems like it would be a lot of work, but it would be cool! Could you just do away with the ignition and replace with a button to make the connection instead of a key. Of course you would lose the security of a key. Im curious to know what would be involved with this.
Old Apr 27, 2007 | 01:16 PM
2kbluevette's Avatar
2kbluevette
I am working with the electronics to get rid of my keys and keyholes.
One will be a transmitter that when within range will unlock the doors and keep the car in contact after you close the door.
My ideal, a fingerprint reader at the back of doorhandles and another inside the car for starting.
Old Apr 27, 2007 | 01:17 PM
97C5ENVY's Avatar
97C5ENVY
Those with remote start - "How you bypass the ignition switch needing resistor pellet?"
Old Apr 27, 2007 | 01:33 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
VATS by-pass, DEI makes it (Viper, Python, etc)
Also, those people who are using there stock FOB for starting, what button are you using and what starter interface did you use?
Old Apr 27, 2007 | 01:40 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Originally Posted by captcruz
Which button on your FOB do you use to start it with? and is something you did or had someone do it for you?
I should've clarified.. It's the FOB that came with the Python system.
Old Apr 27, 2007 | 01:41 PM
MyVetteDream
That's a great plan... I'd love to see that when you get done
Old Apr 27, 2007 | 02:22 PM
screw991le's Avatar
screw991le
Ahh, Ok
Old Apr 27, 2007 | 03:08 PM
towerbuzz's Avatar
towerbuzz
Originally Posted by MUKAKsC5
there is, someone done it here on the forum..... do a search i am sure you will find it
The search on this forum is useless....
Why must people say to do a search?
Old Apr 27, 2007 | 03:12 PM
MyVetteDream
Because you can turn up things like this:
http://forums.corvetteforum.com/show...h+button+start
Old Apr 27, 2007 | 03:22 PM
nonsuchpro's Avatar
nonsuchpro
I have a push button start in my 2005 Toyota Avalon. I love the feature and would love it in my C5
Old Apr 27, 2007 | 03:29 PM
WHEW64's Avatar
WHEW64
Way back when "70's" I had the starter button in the cigarette lighter. Great theft deterant.
Old Apr 27, 2007 | 04:07 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
I wired the garage door opener to the lighter once.
Old Apr 27, 2007 | 04:21 PM
  #33
towerbuzz's Avatar
towerbuzz
Ok so you got lucky....
Old Apr 27, 2007 | 04:54 PM
  #34
97C5driver's Avatar
97C5driver
a memeber here has one that I have seen. i think his id is "EVILC5" . either way, i think he uses the key first, then the button to start (placed in the ashtray area).
i would like to do this as well if some lays out a step by step.
Old Apr 27, 2007 | 05:34 PM
  #35
MyVetteDream
It's all good
Old Apr 27, 2007 | 06:15 PM
  #36
Mike73's Avatar
Mike73
Didn't most cars have push button start before the 60's ? I've seen some old 50'ish pickups that actually had a starter pedal on the floor !
Old Apr 28, 2007 | 04:11 AM
  #37
97vetteman's Avatar
97vetteman
I am going to do a push button start on my Vette.
I did this mod on my 99 Z28 and used a silver start button with blue light.
I then changed to the Honda S2000 push button. You have to keep the key for the Vats pass key. I eventually cut the yellow wire to my key and put a bullet conector in there so if I needed to plug it back in I could by removing the knee bolster panel
I am trying to find the wiring instructions I used and I will post a link. I used a relay and wiring was quite simple.
Here is a pic of the S2000 start button in my 99 Z28 (now sold)
Here is the original silver start button I fitted lit up at night in the 99 Z28
I want this button to go in my 97 Vette to match up with my blue LED interior
I loved this mod in the Z28 it was so cool to have push button start.
All the latest high performance cars are going back to push button start.
I have found the link I used to do my 99 Z28 push button start I am sure it would be very simple to do this on th Vette as the wiring is even easier to get to than the Z28's was.
http://www.pitreweb.com/s2000sw.htm
To Push button start
Old Apr 28, 2007 | 08:11 AM
  #38
drbvac's Avatar
drbvac
Funny when I started this thread before everyone wrote in and thought I was nuts to even try it! Anyway this outfit makes one for th C5 that goes in the cigarette lighter, not here now but was last week.
http://search.stores.ebay.com/Simple...309522QQsofpZ0
Old Apr 28, 2007 | 09:41 AM
  #39
Vette-kid's Avatar
Vette-kid
Id be a little cautious about a company that offers a "Corvette C7" push button.
Old Apr 28, 2007 | 10:26 AM
  #40
NOT2MELO's Avatar
NOT2MELO
Pushbutton (Honda s2000) start in Mazda Mitas with a good writeup for some ideas.
http://www.revlimiter.net/mods/s2000_button.html
http://www.angelfire.com/mac/brb/brbindex.html
