Very good article and explains some of the physics involved. In order to prevent local oscillator "bleed back" through the antenna, one particular method that is employed is to use mutiple RF stages (preferrably 3) through which the incoming signal passes and it's these that prevent the signal from being radiated back out. Naturally it costs more to build a receiver with 3 RF stages in it and can account, in part, for the added price.
The design of military electronics equipment has had this requirement for a very long time and the existence of local oscillator feedback also accounts for the FAA's ban on electronic devices during certain critical stages of flight so as to not interfere with any onboard Nav/Comm equipment.
Yes Virginia, receivers can (and some do) transmit.
Reason: Typos; yak!
Incorrect, most do have "leakage" and "may" interfere with each other. That is how some police systems can detect if you are using a radar detector.
Ok..Ok..after reading the guysoflidar info I am humble enuff to change my position on "it's not a good idea to run two together" as I did not thoroughly understand the oscillator issues prior to this. I've been aware of leakage issues for a while, considering Virginia's LEO radar detector "detectors"...but didn't and still don't consider radar detectors in general as active transmitters. They don't transmit a signal per se, but rather they bleed some of their own electrical activity. After reading the article I now understand this issue much better.
I ran an Escort 8500 for about 1.5 months, just for kicks a couple of years ago It didn't do squat for me... I had CHP all around me and never went off.
