Convertible Zo6
Old Apr 28, 2007 | 05:16 PM
msb184's Avatar
msb184
Default Convertible Zo6
Does anyone know the official reason Chevy won't build high hp Corvette Convertibles anymore? Are they saying it can't be made stiff enough? If that were so, every blown 427 C-5 or C-6 should twist into a knot (including mine) !! I know the C-2 & C-3 cars had a frame . In any case there are hundreds( or thousands?) of modified late model 'verts around to kill that thoery. Every other builder of exotic cars, including Dodge, builds high hp Convertibles. What's the deal? WHILE I'M ON A RANT..... NHRA needs to look at the 13.99 roll bar rule. The old Wally Parks B.S. about NHRA needing to be tax-exempt because they "fought illegal st. racing" is long gone ,they could get back to real rules for real people
Old Apr 28, 2007 | 05:17 PM
everett36's Avatar
everett36
Originally Posted by msb184
Does anyone know the official reason Chevy won't build high hp Corvette's anymore? Are they saying it can't be made stiff enough? If that were so, every blown 427 C-5 or C-6 should twist into a knot (including mine) !! I know the C-2 & C-3 cars had a frame . In any case there are hundreds( or thousands?) of modified late model 'verts around to kill that thoery. Every other builder of exotic cars, including Dodge, builds high hp Convertibles. What's the deal?
Old Apr 28, 2007 | 05:29 PM
02MillenniumVette's Avatar
02MillenniumVette
I dont know for a fact but its probably a liability issue. Would be interesting to know the reason though.
Old Apr 28, 2007 | 05:31 PM
Sick Z06's Avatar
Sick Z06
Frame Twist. Would end up to alignment and stability issues. The work needed to counter act the reinforcement of the convertable would add way too much weight and only slow it back down.
Old Apr 28, 2007 | 05:40 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
I'm not sure the question is even valid. My vert has the same HP as every coupe and FRC out there except the Z06. The C6 verts have 400HP just like the C5 Z06. The only model with more HP is the Z06 (in both C5 and C6) and I'll bet it has nothing to do with twisting or anything else. It is so the Z06 will be set apart from the rest like it was intended to be.
Old Apr 28, 2007 | 05:44 PM
02MillenniumVette
I think he was just asking why GM doesnt offer the Z06 from the factory in convertible form instead of the FRC.
Old Apr 28, 2007 | 05:51 PM
jbondfl's Avatar
jbondfl
I thought of that but the Z06 is a Race Car. Just without the C5R headlights. That is what sets it apart. Seems like if you put the same engine and suspension in a vert (which I doubt would be a problem), or coupe the the Z06 wouldn't even exist. What would be the point?
Old Apr 28, 2007 | 06:10 PM
Sick Z06's Avatar
Sick Z06
So you'd be saying that the difference from the c5 to c6 frame does NOT make up for that?
Old Apr 28, 2007 | 10:40 PM
BanditDude's Avatar
BanditDude
The Z06 is built as the pinnacle of Corvette performance. As such, it is expected that folks will want to take them racing. A coupe doesn't need a rollbar to run the typical HPDE or drag race. However, it is nearly impossible to fit the required rollbar into a convertible without rendering the top inoperable. Plus, a convertible will always weigh more than the equivalent coupe.
Old Apr 28, 2007 | 10:58 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
To start with, it depends on whether you're talking about the C5 or the C6 because there are different reasons for each.
For the C5, it was due to the somewhat convoluted path taken by the FRC body style. When it first came out in 1999, it was originally designed as a price leader offering few frills, hence no convertibles. It was supposed to offer the maximum performance for the least money. This marketing idea expanded later when the Z06 was released although it had been found since then that the standard targa coupe is actually more aerodynamic and hence slightly faster, all other things being equal. That's why the professional race teams used the targa coupe rather than the FRC. So to address your comments, there really was no reason why there couldn't have been a C5 Convertible Z06.
When the C6 came out however, a real, functional reason was designed into the car. The standard C6 coupe and convertible have the same sort of steel hydroformed frame that the C5's have but the Z06 has an Aluminum body structure with one-piece hydroformed perimeter rails frame and magnesium front cradle. This aluminum/magnesium frame is significantly lighter than the standard frame but not as rigid. Therefore it needs the top to maintain structural rigidity.
Old Apr 28, 2007 | 11:03 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Ugh... so much misinformation.
*C5 were designed to be verts from the start... chassis is very strong, no additional bracing needed
*No issues w/ frame "twist"
*Z06 is meant to be a tack car
*If you want a faster vert then mod it.
Old Apr 28, 2007 | 11:15 PM
C5naples's Avatar
C5naples
If it is that important take your vert to lingenfelter or callaway and have them add whatever horsepower your wallet will allow It is only a matter of time next year the base car is supposed to have 430hp, I think
Old Apr 28, 2007 | 11:19 PM
02MillenniumVette
Is that why there was no convertible in '97?
Old Apr 28, 2007 | 11:21 PM
DBL001's Avatar
DBL001
actually they fit the rollbar in quite nicely, I've seen them done and they don't hinder operation of the top at all, and also like mentioned above, the c5 was designed with the vert in mind for the future, the vert weighs the same as the coupe, granted not the Z but that has a lot of weight saving features that could be done to a coupe or vert
Old Apr 29, 2007 | 08:11 AM
JACKAL0PE's Avatar
JACKAL0PE
No. That was marketing. The 97 C5 coupe was the big story that year and they sold every one they could make. The convertible in 98 only kept the fire going.
He's right that the C5 was designed for both coupe and convertible from day one. That's why there's only a very few light extra pieces of bracing used on the convertible.
Old Apr 29, 2007 | 06:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
here's a convertable Z06:
Old Apr 29, 2007 | 06:30 PM
M6 Vetter's Avatar
M6 Vetter
To Convertible Zo6
Old Apr 29, 2007 | 08:14 PM
JPM@AutoBuffs's Avatar
0JPM@AutoBuffs
Former Vendor
From: The AutoBuffs Army is unmatched in the Custom world! www.autobuffs.net
S. Jersey Events Coordinator
St. Jude Donor '08-'09-'10
Cruise-In IX Veteran
Old Apr 29, 2007 | 08:22 PM
JACKAL0PE's Avatar
JACKAL0PE
So here's the question, did he take a Convertible and make a Z06 out of it (in which case it really isn't) or did he take a Z06 and cut the top off?
Old Apr 29, 2007 | 08:36 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the latter.
the guy owns a local body shop. you can see the custom fender flares (not maxacc) and the smooth front license plate area.
