DTC B2860 Telescoping Column Position Sensor Failure
C2115 Left Rear TPM Sensor Malfunction
I reset these and then I went to the gas station and filled up with gas and made sure I turned the cap until it clicked 4 times. We drove around for around an hour this afternoon and the check engine light didn't come back on.
We just took it for a cruise and the light came back on.
These are the codes it's showing now.
After resetting these are the codes that came back.
Does it come on right around when you're at about 2000rpms in 1st gear and the shift light comes on?! If so it is probably because of your 1-2 shift eliminator. Did you have a C/E light before installing that part?
