odd issue (help)
Old Apr 30, 2007 | 10:48 AM
Warnberg
Guest
Posts: n/a
Default odd issue (help)
I'm not sure how this happens but my stock air intake box, where the filter goes, keeps popping the latches. I re-latch everything down take it for a drive and everything will be fine. Next time I fuel up I check the oil and one or both of the latches will be off.... Anyone else seen this? Is there someway to correct it?
Thanks,
Old Apr 30, 2007 | 10:51 AM
vpunteney's Avatar
vpunteney
I have the same issue, looking forward to a fix from the group.
Vinnie
Old Apr 30, 2007 | 10:52 AM
peachtreeplaya's C5's Avatar
peachtreeplaya's C5
I'm not sure but I notice this happens with my C5 as well could this be a possible reason for some of the HVAC codes I get from time to time?
Old Apr 30, 2007 | 10:57 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
The design of these latches svcks!!!
The only fix I know of is to adjust (bend) the straps until you beat them into submission. It is possible to do, but takes some patience...
Old Apr 30, 2007 | 11:03 AM
VinnyT's Avatar
VinnyT
Here's what I did before going aftermarket. Cut a 1/2" or 5/8" rubber hose roughly 2" long. You need to pieces. Unhook the latch to loosen the top strap. Place one hose underneath the strap, hold it there while re-latching the cover. Do the same with the other strap. Basically, the straps get stretched over time. The hose helps regain the tension that keeps the latches taught. Worked great for me.
V.
Old Apr 30, 2007 | 11:09 AM
Warnberg
Guest
Posts: n/a
Sounds to me like a cold air intake is in the near future my car, but which one..... hummmm
Old Apr 30, 2007 | 11:50 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I've dealt with this problem on my high mileage '99 as well. I think the straps actually stretch over time due to being tight and adding a large dose of engine-bay heat. I finally gave up and put on my only mod, a Halltech Induction.
Old Apr 30, 2007 | 04:18 PM
Oldvetter's Avatar
Oldvetter
I used a small piece of duct tape on my 1998, but when I changed to a 2002 Z06 airbox lid I had no more problems.
Old Apr 30, 2007 | 04:25 PM
VinnyT's Avatar
VinnyT
Oldvetter, that 98 wouldn't have been red in color, would it?
Old Apr 30, 2007 | 04:26 PM
sliebl's Avatar
sliebl
V.
I did the same fix, but used two small pieces of double-wall cardboard, placed down low so they can't be seen, since the fix is about as silly as they come.
I did this until I find a better method... I like the hose fix. Maybe I'll try that until I get a cold air intake.
Old Apr 30, 2007 | 04:44 PM
jrose7004's Avatar
jrose7004
I'd get a different intake!
Old Apr 30, 2007 | 04:49 PM
hotwheels57's Avatar
hotwheels57
A common mistake is installing the ends of the metal straps at the wrong location of the bottom part of the assembly. That makes them loose and will allow them to come off because there's no tension.
You should probably remove the entire assembly and attach them correctly, bending the ends if necessary to keep them in place, then reinstall the assembly.
Old Apr 30, 2007 | 04:52 PM
dndrsn's Avatar
dndrsn
I flipped it.
Old Apr 30, 2007 | 05:27 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Ziptie?
Old Apr 30, 2007 | 09:25 PM
lawZ's Avatar
lawZ
do the ziptie!
Old Apr 30, 2007 | 09:26 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
To odd issue (help)
