Computer Aided Gear Selection At certain RPM's a computer in your transmission will force you to shift from 1st to 4th. It was designed to help with gas mileage.
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
It kept GM from earning the gas guzzler tax on the C5.
It works this way:
1. The engine coolant temp is higher than 120 degree F.
2. Your speed is between 15 - 19 mph
3. You are at 21% throttle or less
It can easily be defeated by shifting at higher RPM's, without purchasing the CAGS Eliminator for about $20.
