Clutch adjustment question
Is there any setting to adjust the clutch on a MN6?
1. Can I set the grab point of the clutch pedal?
2. Can I set or adjust the amount of pressure the plates hold with?
I have about 75K on my car and the clutch is strong I changed the tranny fluid around 70K, I can put the car in 6 gear and go WOT without any slipping. Nomal use is perfect...
But...
When I am launching from a stop with agressive RPM ~4000 the clutch seems to slip and I can smell it also...
What is going on?
