Battery advice please
Old May 3, 2007 | 04:39 PM
finallyownone's Avatar
finallyownone
Default Battery advice please
Went to start the car and go figure needs a new battery. My quesiton is I know in the past I have read many posts about kinds of batteries to use. For some reason optima red top rings a bell but just curious if anyone could please chime in and mention what battery to get or just the same one that came in it from the factory. It's an 04. Thanks for any help.
Matt
Old May 3, 2007 | 10:17 PM
ROJ#79's Avatar
ROJ#79
I have the Optima Red top in my '99 and I'm very happy with it.
It's been in for 3 years and all I do to it is but a battery tender on it for the winter when I'm in Florida. I purchased the tender at Harbour Freight for $8.oo on sale.
Old May 3, 2007 | 10:25 PM
Oldvetter's Avatar
Oldvetter
Exide Orbital, an AGM battery, reasonable price, good warrenty and has worked fine for past four years for me.
Old May 3, 2007 | 10:27 PM
Batmbl's Avatar
Batmbl
Optima Red for me. 2 yrs., no problems.
Old May 3, 2007 | 10:36 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Optima----Hell No ....Overpriced POS that has a long history of premature cell failure. Buy anything but an Optima
Old May 3, 2007 | 10:54 PM
Secret237's Avatar
Secret237
I'm telling ya ... Sears DieHard Platinum.
Old May 3, 2007 | 11:19 PM
tellefan's Avatar
tellefan
Excide Orbital, Napa and NTB sells them. You can get one shipped to your door pretty cheap, remmybattery.com David
Old May 4, 2007 | 01:14 AM
silverbullit99's Avatar
silverbullit99
Since last summer I've tried 3 different batteries. The Red top was installed last summer. It just didn't keep the charge,,, Then I tried 2 other brands still same problem. I took the vette to the dealer to have it checked. What they found was that the cable bolts that attach to the battery were just a bit longer so it was not making a tight connection. I replaced that battery with a GM Delco battery 720.
Haven't had a problem since. If you are worried about the Delco leaking... I bought a battery pad just in case.. So I recommend you get the Delco battery, at least 720 amps..
Old May 4, 2007 | 02:38 AM
DeeGee's Avatar
DeeGee
Take a look at this thread to decide how the various batteries perform
http://forums.corvetteforum.com/show....php?t=1469503
My assessment for what its worth. I honestly think that many of the problems you see here are car not battery problems. The Vette is a power guzzler even when its switched off.
The AC Delcos have a very high failure rate although they are by far in the majority as the stock battery. The older ones leak and the damage is significant as the computers are under the battery tray. People say that the newer batteries have been improved. I've had a leaker and a early failure (at 8k miles) so they are not my favorite batteries.
The Optima Red Top is a great AGM battery (wont leak) but does not like being discharged. If you go for that get a Battery Tender. the Yellow Top should cope better with irregular use as its a deep cycle battery. Optima have a good warranty.
The Exide gets a good press and seems to have a low failure rate.
In any event, if your Vette is not a DD get a tender.
Old May 4, 2007 | 03:19 AM
thug29's Avatar
thug29
I too have the Optima Red Top Battery and I also had a "Battery Brain" installed onto it. If for some reason your Optima dies out (sometimes mine will drain low from playing the DVD for hours) this "Battery Brain" is a button which is located on top of the battery itself, you just push it and you get instant juice, enough to kick the car over.
Old May 4, 2007 | 07:50 PM
midlifetoy1's Avatar
midlifetoy1
Default Battery Advice
So will the Red Top be a good choice for a daily driver?
Old May 4, 2007 | 07:58 PM
RonJ's Avatar
RonJ
Hasn't missed a beat yet. It's on a battery maintainer all winter if that makes a difference.
RonJ ...
Old May 4, 2007 | 08:01 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Just purchased and need to install this battery in my car as well. I believe this is the way to go. $180 though! Ouch!!!!
Old May 4, 2007 | 09:45 PM
tony2003's Avatar
tony2003
Default delco's ok with me
I've had great luck with delcos in corvettes and my z28. I disconnect battery on nov 30, and reconnect early april and it always restarts on its own power. no battery tender! still original in 03-works fine good luck
Old May 4, 2007 | 10:00 PM
JohnTheStigGalt's Avatar
JohnTheStigGalt
Heard WAY TOO MANY bad things about Optima Red Top. I recently bought an EXIDE Orbital from NAPA. VERY happy with it!
Old May 4, 2007 | 11:14 PM
george's2001c5's Avatar
george's2001c5
I have always had good luck with interstate batteries. I have had a interstate in my 01 for 3 years no problems. Use a battery minder when setting for long periods. Also have had great luck with sears diehards in my other cars. A vette shop in my area recommended the interstate and said to stay away from the red tops. They have nothing but problems with them. I checked at a local repair shop in my area that stopped selling the red tops. Alot of problems he also recommended the interstate battery. I called corvette mike for a recommnedation also he recommended staying with delco and against the red top.
Old May 4, 2007 | 11:21 PM
Batmbl's Avatar
Batmbl
Since I have one (Red Top), I'd be interested to know what some of those bad things are?
To Battery advice please
Old May 4, 2007 | 11:43 PM
B Taylor's Avatar
B Taylor
St. Jude Donor '08
Just bought an Exide Orbital from Checker.
Old May 5, 2007 | 01:40 AM
OMG's Avatar
OMG
Had a yellow top for over a year before someone forgot to disconnect it during a winter storage (my parents had to move it). It died that winter. But after charging it for 40 mins it started up again and has been working ever since.
Old May 5, 2007 | 02:12 AM
DeeGee's Avatar
DeeGee
Quite a few members have had early failures
Having watched these threads for a long tme I think its more aproblem with the Vette than the battery. The Vette seems to have a constant drain. Couple that with a lot of cars that sit idle sometime for weeks on end and they may have after market audio units, charging devices and all sorts of things that pull a little power. If the battery isn't hooked up to a battery tender it goes flat.
The Red Top doesn't like being discharged to zero and seems to die at that point.
I've had Red Tops on both mine and my son's Camaro. Both cars were shipped to England last year. My sons fired up straight away. Mine was a s dead as a doornail. I tried recharging but no joy.
As a daily driver, my Red Top ran fine for 2+ years. Idle for 2 months and it was terminal. I now have a battery tender hooked up to a new Yellow Top which should cope with irregular use better.
The main advantage for me is that even dead, a Red Top will not leak, unlike the AC Delco I took out of the Camaro which left a small present ( battery acid on the tray).
I could be way off but just my thoughts.
