im pissed
Old May 5, 2007 | 11:52 PM
STEEL's Avatar
STEEL
Default im pissed
I bought an aussie clutch from textrilla with the aluminum flywheel, and all of a sudden I was pulling into work and heard a grinding noise when I let the gas go and, still had the clutch depressed. It seems to be fine one take off, and normal driving. I don’t race my car, I just use it for daily driving and I put about 5,000 miles on the new clutch if that. What should I do call the company and demand a new clutch? And what about the 500 dollars for labor? Any suggestions?
Old May 6, 2007 | 12:40 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
who installed it??
maybe its an install issue not the clutch
Old May 6, 2007 | 01:35 AM
blacksedan87's Avatar
blacksedan87
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Originally Posted by pewter99
who installed it??
How do you know that the product was defective and the install was fine? Frankly - I'd be talking to the installer before I spoke with anyone else.
Also - just curious, why go with an aftermarket clutch for a car that is only daily driven and never raced? Why not just go with a standard LS1 clutch? None of my business really, but I am curious.
Old May 6, 2007 | 02:37 AM
STEEL's Avatar
STEEL
The person who installed it came recommend by the forum, he works for GM and does installs on the side,
I killed the stock clutch drag racing and I replaced it with a high performance one because I plan to race but I wanted to finish school first so if I did break something I could replace it without having to worry about the added expense.
Old May 6, 2007 | 07:10 AM
I agree, speak with the installer first and see if there are any problems there. If not, and it can be traced to problems with the clutch itself, then a call to the vendor would be a good choice.
Old May 6, 2007 | 08:58 AM
WvCorvette's Avatar
WvCorvette
Old May 6, 2007 | 10:45 AM
blacksedan87
In your first post you wrote......
In your reply you wrote......
I don't get it - you race the car, but you say you don't and then complain about the clutch being bad, but it was installed by some amateur shade tree mechanic.....good luck.
Old May 6, 2007 | 11:14 AM
M6 Vetter's Avatar
M6 Vetter
Old May 6, 2007 | 03:09 PM
STEEL's Avatar
STEEL
I killed my first clutch racing that’s why I don’t do it anymore until im out of school so I can afford to break things, but I already killed the stock clutch so I had to change it so why not get a high performance one because I would like to race again.
Kyle that works at revxtreme and a guy Mike did the work for me and they came recommended.
STEEL's Avatar
STEEL
Does anyone know what the grinding noise could be?
Old May 6, 2007 | 08:48 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Take it apart and find out. Internet diagnoses are worth what they cost.
Old May 6, 2007 | 10:06 PM
Brad@RevXtremeAutoSports's Avatar
Old May 6, 2007 | 10:12 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old May 6, 2007 | 10:54 PM
BAD AZZ C5's Avatar
BAD AZZ C5
St. Jude Donor '06
Old May 7, 2007 | 07:36 PM
STEEL's Avatar
STEEL
I called both texrailia and the installer and, have not gotten a call rack yet.
Old May 7, 2007 | 08:13 PM
M6 Vetter's Avatar
M6 Vetter
To im pissed
