[Z06] Question about frames
Old May 7, 2007 | 07:56 AM
nepafrankC5's Avatar
nepafrankC5
Default Question about frames
Are all c5 frames the same? I have a reconstructed Z. The left tire sticks out 3/4" of the wheel well. The car drives straight and took the alignment fine. But I was tossing around the idea of swapping the frame out.... What are your thoughts?
Old May 7, 2007 | 09:53 AM
VicCaerter's Avatar
VicCaerter
body isnt straight. other than that, no idea without looking at it.
Old May 7, 2007 | 10:06 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Swapping the "frame" out is not as simple as it sounds. You would be better off placing your body panels on another undamaged C-5 Chassis.
Old May 7, 2007 | 12:17 PM
Bill Dearborn's Avatar
Bill Dearborn
A bunch of possibilities. It could be the body shop didn't get the inner fender liners mounted correctly. If they are not mounted correctly the fenders will be off. I would assume the front end body panels must not be centered correctly. Not sure what you meant by taking the alignment correctly. There is a fair amount of adjustment in the alignment if somebody added a lot of shims behind the upper control arm mounts they could push the top of the front wheel out quite a bit. Take a look at the control arms and see how the lower alignment cams are set and how many shims are being used on the upper arms. If you bought the car used it may have the lower cams replaced with a T1 type setup that pushes the lower control arm out to gain a lot of negative camber. Then to get a normal alignment a shop would have to add a lot of shims at the top.
Bill
Old May 7, 2007 | 12:48 PM
nepafrankC5
Sorry for the lack of info. Its the Left Rear tire thats sticking out.
Bill
Old May 7, 2007 | 01:09 PM
nepafrankC5
Another possibilty is that a convertible quarter panel was used. Just a guess. Is there a difference? Besides the part number.
To Question about frames
