car wont start
Old May 9, 2007 | 09:07 PM
borisshnitkin's Avatar
borisshnitkin
Default car wont start
i went to the store and came back and the car wouldnt start. i called my freinds to jump me and it did fine. drove it for like 10 min, came home and it wouldnt start. u hear it try to crank. what can the problem be?
Old May 9, 2007 | 09:11 PM
Mr. Couture's Avatar
Mr. Couture
maybe a new battery?
Old May 9, 2007 | 09:31 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yeah, bad battery or battery connection at the cables
Old May 9, 2007 | 09:41 PM
04cad's Avatar
04cad
St. Jude Donor '07-'08
Someone on CF said: batteries are for starting, alternators are for driving. Check and clean your connections and after you tighten them check to see if they are still loose. Another thread had a post about some batteries the post bolt would bottom out and feel tight but the cable would still move. Guaranteed to cause intermittent problems. Good luck with this and try carrying an adjustable wrench with you in case you need to change out the battery or tighten the bolt to make it work until you get it fixed permanently.
Old May 9, 2007 | 11:42 PM
borisshnitkin
i hope its just the battery. i played with the wires, and it would flicker but wouldnt be normal. so tomorrow ill go get a new battery and hope for the best
Old May 10, 2007 | 01:33 AM
DeeGee's Avatar
DeeGee
Did you back off to parking lights when you were fixing your broken headlight? If you left it on maybe you killed the battery. Try a recharge.
Old May 10, 2007 | 07:16 AM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I would check all the connections before jumping out and buying a new battery, I had a 1999 Z28 and because it was nicely modded, the battery connections would loosen which caused it to do the same thing.
Hope it is a cheap and quick fix.
Old May 10, 2007 | 05:25 PM
borisshnitkin
it was the battery!!!
Old May 10, 2007 | 05:38 PM
happa's Avatar
happa
wished mine was, mine did the same thing and had everything checked out starter, everything, stil cant figure it out. Glad yours was easy, now throw some luck this way!
Old May 10, 2007 | 05:46 PM
drews60's Avatar
drews60
Just out of curiousity, did you check your DIC for a voltage reading?
Old May 11, 2007 | 10:20 AM
DeeGee's Avatar
DeeGee
The DIC voltage only works when the car is running BTW
Old May 11, 2007 | 10:24 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Bad terminals - not clean
My battery cells blew and the battery was destroyed inside!
Take it out and have it checked or borrow one from a friend to see if it is the problem.
Just remember you will need to reset your KeyFob and Radio if you have it on the anti-theft lock! SEE OWNERS MANUAL FIRST! on how to reset or diengage the Anti-theft Radio feature follow instructions on FOB's per Manual!
Thanks,Matt
To car wont start
