iforged wheels
Old May 14, 2007 | 11:21 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by BAMF AE
Tom, thanks for the explanation! In your opinion, would it be better to go with Hubcentric or Lugcentric?
Although I'm not Tom, I'd say hubcentric anytime.
Old May 14, 2007 | 11:23 AM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Originally Posted by Y2Kvert4me
There are 2 types of centering methods used on wheels, hubcentric, and lugcentric.
Thanks for the in depth explanation,now I understand the difference.........
But,I have to say,I am not aware of ever having a hubcentric specific wheel in my entire life,and have never had a single issue
I just don't see the advantage claimed unless you have a monster truck or the like
Old May 14, 2007 | 11:26 AM
reactor2's Avatar
reactor2
Quality is fantastic. Mine have been on the car over 4 years now, no complaints.
I've owned lots of custom wheels over the years, including HRE's, and these Iforged's are right there at the top in finish and construction quality.
What size wheels/tires are those? I'm debating between 18/19's and 19/20's for mine.
Old May 14, 2007 | 03:26 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
19x9.5 front, and 20x10 rear.
Tires are 275/30/19 front, 285/30/20 rear.
Old May 15, 2007 | 09:07 AM
andyandy98's Avatar
andyandy98
Has anyone had issues with their Tire Pressure sensors not working with the IForged wheels??
Old May 15, 2007 | 10:17 AM
zguy's Avatar
zguy
Originally Posted by lytspeed1
What size wheel and tires ???...Those look great
19x9.5 front, and 20x10.5 rear.
No problems so far since original mounting over 3 years ago.
Old May 15, 2007 | 10:38 AM
DRKMATTER's Avatar
DRKMATTER
St. Jude Donor '09-'10
For my order....the Wheels came in almost perfect (wasn't happy with the quality of the polished aluminum of the rear lips but the overall construction was very sound). As I've stated many times in the past...IMHO the customer service was deplorable!!!!
Great Wheels
Horrible Customer Service
Old May 15, 2007 | 10:49 AM
TNT C5's Avatar
TNT C5
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
No problems with the TPS but they do have to be banded - they won't work through the valve stem hole.
Old May 15, 2007 | 10:55 AM
DT's Avatar
DT
Hubcentric means the center bore of the wheel is sized to fit perfectly over the hub of the car, the duty of centering the wheel and supporting the load of the car is the job of the hub. The job of the lugnuts and studs is only to fasten the wheel to the hub, not designed to support the load of the car.
Lugcentric, means the lugnuts not only tighten the wheel, but they also align it to the hub, and essentially support the load too. In this case, the center bore of the wheel can be much larger than thus hub, it doesn't matter.
The reality is MOST modern cars out there use a combination of both. If it uses cone or ball seat lugnuts, the wheel will end up centered, even if the hub bore of the wheel is bigger than the hub.
Custom wheels often use thin rings to shim and make the wheel fit tightly on the hub, which helps to prevent any possible vibration issues, and to also reduce the load on the lug studs.
Plastic, although it seems cheap, is the common material to use in this adapter ring application, because mixing steel and aluminum in a tight fit (wheel bore-to-hub) produces rapid corrosion due to the dissimilar metals, and getting an aluminum wheel that's corroded and bonded itself to the steel hub can be a real bitch to remove if they've been on for a long time.
Holy Smokes! Thank you Dr. Wheel, good answer
Old May 15, 2007 | 12:16 PM
andyandy98's Avatar
andyandy98
TNT C5 I sent you a PM.
Anyone else use the banded method of securing the TPS sensors? Does this hold up over high speed and time?
Anyone know a good place to buy the bands?
Old May 15, 2007 | 01:11 PM
VYC6's Avatar
VYC6
Yes. I purchased iForged wheels for my C6 Corvette and I used the Strap Kit for the TPMS Sensors and have had no problems. They work and function awesome. I highly recommend them. HRE also uses the Strap Kit.
Old May 15, 2007 | 01:30 PM
andyandy98's Avatar
andyandy98
Where is the best place to purchase these bands???
Old May 15, 2007 | 01:39 PM
  #33
TNT C5's Avatar
TNT C5
Cruise-In V Veteran
I got mine from Xtreme Motorsports in Phoenix....
http://www.xmsengineering.com/wheels/
I see they've gone up in price since I bought them.. Corvette tax strikes again!!
Old May 15, 2007 | 02:09 PM
  #34
zguy's Avatar
zguy
I used this method as well when I installed my sensors. I was actually lucky enough to get the bands from Tom (Y2Kvert4me) when I did mine. I am not sure what it cost him back then but I don't believe the bands he used were even associated with vettes or even cars for that matter. I would send him a PM he might be able to recommend an alternative to the kits specifically made for vettes. Good luck...
Old May 15, 2007 | 02:28 PM
  #35
snitz's Avatar
snitz
First pic is of my Iforged Aero's(street bling: Pilot Sports) and the 2nd is of my CCW Corsairs(track R compound Pilot Sport Cups). The Iforged are better looking and cost approx 60% more. The CCWs are lighter and a better track wheel. Both are well made, CCW is a one piece, Iforged a 3 piece. For bling go Iforged, for performance and value go CCW. If you want top of the line road race wheels go Fiske.
Old May 15, 2007 | 02:44 PM
  #36
andyandy98's Avatar
andyandy98
I appreciate all the replies about the straps to hold the TPS -THANKS EVERYONE WHO CHIMED IN. I didn't mean to change the subject matter of the thread sorry.
Old May 15, 2007 | 04:29 PM
  #37
PMPN8EZ's Avatar
PMPN8EZ
just an fyi ....
I have a set of HRE 540's where the sensors were epoxied (spelling?) to the wheels. I've had the set for what 5+ years now and have never had a sensor detach itself from the wheel.
I have a set of Iforged heels where I don't run any sensors ... although I should as I have no sidewall.
HRE 540 Wheels: Stock sizes.
Iforged Daytona Wheels: Front 19x10 (275/30/19) Rears 20x11 (305/25/20)
To iforged wheels
Old May 15, 2007 | 04:36 PM
  #38
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
My epoxied/banded sensors have been just fine for the last 4 years.
More info and pics about the process, see my posts in this thread:
http://forums.corvetteforum.com/showthread.php?t=928471
Old May 16, 2007 | 03:07 PM
  #39
aTX427
Guest
Posts: n/a
Great wheels - **** poor customer service. I used to sell iForged and dropped them for HRE because they do not stand by their products.
Old May 16, 2007 | 08:29 PM
  #40
EuroC6ive's Avatar
EuroC6ive
Talk to ElusiveFx.com...
The way i look at it, as long as you go through an authorized dealer who can take care of your needs, you wont have a problem with iForged. I have yet to have any issues since i started dealing with Elusivefx.
