changed my battery
Old May 12, 2007 | 05:58 AM
caincarter's Avatar
caincarter
3rd Gear
Default changed my battery
well i changed the cars battery hooked up the new one
the radio works fine but the cd player doesnt work anymore
its the trunk mounted cd changer
anybody had this problem before ?
thanks in advance. cain
Old May 12, 2007 | 06:35 AM
Ron222's Avatar
Ron222
Changed my battery a few months ago...put in a red top...no problems with the cd changer didn't even have to reset the the radio channels. Don't know what happened but I think its coincidental and that you may have a loose connection somewhere. Just my .02
Old May 12, 2007 | 07:31 AM
Wouldn't think that just changing the battery would affect the CD changer like that.
Old May 12, 2007 | 08:28 AM
tellefan's Avatar
tellefan
Take a look in the car audio section. There is an article about this, it states that you need to unplug the harness at the changer and plug it back in. You might have to do this several times to get the head unit to recognize the CD Changer. Hope this helps. David
Old May 12, 2007 | 09:02 AM
jimcork1's Avatar
jimcork1
Open the cd, remove the magazine,, reinstall close the door and listen. You should hear the cd's indexing through a full cycle. Give it time to complete the cycle before you try to use it. I have had this before. Jim
Old May 12, 2007 | 09:09 AM
jrose7004's Avatar
jrose7004
Old May 12, 2007 | 10:58 AM
Jistari's Avatar
Jistari
From the last time this popped up:
Originally Posted by Jistari
Take a look at the post on unlocking a radio in theft mode. I know, yours is not in theft mode, niether was mine, but after changing the battery it wouldn't let the XM radio I have plugged into the 12 CD changer input through.
Same symptoms (when I press Aux it powers up the XM and goes to Track 1 1 but no sound).
In trying the instructions for getting the radio out of lock mode the first step was to press preset buttons 2 + 3 (if i remember correctly), so I did that and poof, all was well (didnt have to follow through with the rest of the instructions, XM just started working).
Worth a try, good luck.
Old May 12, 2007 | 12:53 PM
WetteVette's Avatar
WetteVette
Thanks for the tips, guys. I'm getting ready to change out my battery also.
Old May 12, 2007 | 03:12 PM
Ryan's Daddy Dan-Na's Avatar
Ryan's Daddy Dan-Na
Default batter change
I changed my battery prior to joining this forum, bought the regular liquid filled battery from Costco and didn't know. I just changed the battery and I had no problem at all with my CD changer being recognized.
Old May 12, 2007 | 03:33 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The changer needs to be cycled. Just unplug the changer at the changer and plug it back in.
Old May 12, 2007 | 03:42 PM
nonsuchpro's Avatar
nonsuchpro
Thanks!
Old Jun 4, 2007 | 05:45 PM
z064ddle's Avatar
z064ddle
I'm having the same problem. Plug & unplug the connector at the changer many times, still doesn't work. Remove the magazine and put back in few times, still doesn't work. I guess I'll have to try the reset the lock mode and see what happen.
To changed my battery
