rear end plug
May 12, 2007 | 04:28 PM
rear end plug
I attempted to change the rear end fluid this morning but the biggest size i could find is 3/8 and its not right, close but i dont want to strip it, and it is TIGHT. ( I broke the 1/4 drive)
I assume its in MM's as well?
Oh and is the tranny the same size? Ill be doing that as well.
May 12, 2007 | 04:47 PM
Been awhile since I've done mine, but for some reason 10mm comes to mind.
Anyone else?
May 12, 2007 | 04:48 PM
I think your close if not right, I was searching more and found the c6 is 10mm,
Im off to the store so hopefully it is 10mm.
Thanks Lonestar
May 12, 2007 | 06:40 PM
Why does GM use metric bolts???
May 12, 2007 | 06:54 PM
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
May 12, 2007 | 06:56 PM
St. Jude Donor '06-'07
Quote:
Originally Posted by
Willfulone
19mm
Peace
Chip
That sounds better 10 mm is too small.
May 13, 2007 | 06:06 AM
Not sure, maybe you guys are confusing what i mean,
The allen key size for the drain and fill plug on rear end,
It is 10mm
May 13, 2007 | 11:06 AM
Try a 3/8 drive extension.
May 13, 2007 | 11:58 AM
photoguy
Supposedly the "new" world standard (many years now) and I am pretty sure most car companies do the same.
May 15, 2007 | 04:10 PM
clayton1
It is 10mm
