[Z06] Window trim question
Old May 12, 2007 | 05:37 PM
SkyWarp's Avatar
SkyWarp
Default Window trim question
I need to remove the plastic trim that goes from the front of the windshield up the roof down to the door handle area. How hard is it to remove and replace?? It looks like it 2 peices. I plan to replace both sides with fresh ne ones. Any help would be great. Tks guys
Rob
Old May 12, 2007 | 09:35 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I just replaced both of mine.
First one was a real PITA. It took longer to clean off all the old adhesive than it did to replace the parts.
I strongly suggest you buy the metal track that holds the rubber weatherstripping. As it is hard to remove that piece without bending it. Mine was covered with adhesive and very difficult to remove.
I also purchased some black seam sealer to use when installing the parts. It's waterproof and remains flexible for life. The item was very difficult to locate but, is recommended by GM for body sealing.
PM me if you have any specific questions. The manual lays out a very detailed plan for where and how much sealer to place in certain areas on the two separate parts. I would follow this very closely to avoid any leaks.
Old May 13, 2007 | 12:46 AM
z06Bigbird's Avatar
z06Bigbird
Rob
Do a search for Gene Culley at gmpartshouse.com. Good man, preferred vendor, discounts on a regular basis, plus discounts if you mention forum involvement, etc.
To Window trim question
