Tuning + comp mode ????
Old May 12, 2007 | 08:46 PM
2klude's Avatar
2klude
Default Tuning + comp mode ????
Is it possible to tune the car to always be in comp mode? Every time i drive my vette i put it in comp mode before leaving the house. I am getting a 150rwhp shot and a tune next week. Just wondering if the tuner can tune the car to always be in comp mode.
Old May 12, 2007 | 08:55 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Maybe, sort of.
I haven't played with this yet in EFI-Live, but in it, you can alter the Traction Control EFFECT settings, ie: the timing retard application...so it seems possible to make Traction Control basically do nothing.
Again, this is something I haven't tried yet, but will try playing with to see if it works. Since it does not effect Active Handling, only TC, it should be "functionally equivalent" to comp mode. The only downside I could think of, is while spinning the tires you would still see the "Traction system active" message on the DIC, even though the PCM is doing nothing to spoil the fun.
If anyone has tried what I'm thinking of, and knows for sure, I'd like to know.
Otherwise, there is a module sold, called the Laptrax, that you can have put your car in comp mode at each startup.
Old May 12, 2007 | 08:56 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Laptrax.
Old May 12, 2007 | 09:11 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by FactoryRaceCar
Laptrax.
More info please...
Peace
Chip
__________________
..................Click for
Old May 12, 2007 | 10:39 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Originally Posted by Willfulone
More info please...
Peace
Chip
Laptrax is an electronic box that keeps your system in competition mode or any other mode without reseting it's self.
Here is a short cut to the company Laptrax
Old May 12, 2007 | 10:54 PM
doug doo wop's Avatar
doug doo wop
so to keep your mode in competition lets you spin your tires all the time? Is the active handling still in affect, if not , that could be dangerous? So is it good to keep in comp mode? Thanks
Old May 12, 2007 | 10:58 PM
Sponge Vette
It doesn't effect the active handling, unless you turn everything to OFF
Old May 12, 2007 | 11:04 PM
mcgilles's Avatar
mcgilles
I wish I could change the way that button works. I think it should have been designed to go into competitive mode immediately by pushing the button, then you have to hold it for like 1-2 seconds before it would turn off active handling. I don't understand why its designed to be easy to turn off everything but harder to turn off just one feature in stock mode. plus I have an early C5 so I have to be stopped in order to go into comp mode. is there any way to fix that?
Old May 12, 2007 | 11:06 PM
FactoryRaceCar
More info please...
Peace
Chip
Chip its a very neat gadget that most of us racers are using for a long time. It works like a charm.
You know, you should start carrying it so there is no Vette tax on it
The best price I have seen is over corvettegarage.com
Old May 12, 2007 | 11:51 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
LapTrax TracActive controller.
Write up and install details here
http://forums.corvetteforum.com/show....php?t=1386537
Old May 13, 2007 | 02:45 AM
pimpjames's Avatar
pimpjames
Now that would be awesome... any tech guru's who would like to try and make a mod for it
Also I don't like how it displays comp mode and blocks out my DIC info
Old May 13, 2007 | 03:09 AM
KapUSMC's Avatar
KapUSMC
Hit the reset button, you still have the DIC, without that dam message. Use it for tire pressure with racing.
Old May 13, 2007 | 04:36 AM
pimpjames's Avatar
pimpjames
Perfect thanks a bunch
To Tuning + comp mode ????
