traction / abs
Old May 15, 2007 | 09:03 PM
Joe Scafide's Avatar
Joe Scafide
Default traction / abs
hello kind of new to the fourm can anybody help. the problem is my abs /traction service comes on but not every time and then when i shut off the car sometimes it resets sometimes stays on all day the car is a sunday driver with low miles on it has anybody else have this problem thanks joe
Old May 15, 2007 | 09:30 PM
Illini82's Avatar
Illini82
St. Jude Donor '07
Most likely EBCM, pull the codes from the DIC and let us know what you find. Search around if you need help pulling codes and finding the sheet of of them (hold DIC button 4 and push 1 four times I think? I need to be in the car to know for sure)
Good luck! Don't worry, if it is EBCM there are relatively cheap fixes that work. I've had this problem and had it fixed in a week.
Old May 15, 2007 | 10:10 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Hi Joe, Follow the directions in this post - https://www.corvetteforum.com/techti...D=26&TopicID=1
make note of any codes you find and post them for us to look at.
To traction / abs
