[Z06] Difference between 2002, 2003 and 2004 Z06
Old May 18, 2007 | 05:30 PM
rustyguns's Avatar
rustyguns
Quote:
Originally Posted by 95cobraR View Post
But we win all of the races; it's why they call it Victory.
They call you guys quick because you can't service your women properly.
Oh you're going straight to hell for that one buddy
Payback is coming
hahahahaha!!!!!!! may your ***** shrivel up and blow away! hahahaha!
Old May 18, 2007 | 11:02 PM
MadMaxZ06's Avatar
MadMaxZ06
Originally Posted by rustyguns
is the returnless a lot better? if so. why?
Like everything in life, the returnless fuel system has its pluses and minuses. Two things that come to mind that are positive:
1. The fuel in the gas tank stays cooler because excess fuel (that was exposed to under-hood temperatures) is never returned back to the fuel tank.
2. The possibility for the fuel pump to make noise (which by the way typically gets worse as the fuel heats up) is reduced because everything is contained inside the gas tank.
The biggest negative about the returnless system is its ability to provide the necessary fuel (read pressure) required by high horsepower applications. BAP (Boost-a-Pumps) are regarded by some to be band-aid solutions by design.
- Max
