C5 Engine Light - Help!
Old May 17, 2007 | 08:06 PM
jerseycarguy's Avatar
jerseycarguy
Default C5 Engine Light - Help!
I drove my 2000 coupe home from work the other day in the rain and I went through a very shallow puddle and a few yards later the check engine light came on. The car did not seem to drive any differently or idle any differently after the light came on. Did the water cause it to come on? It has been a day since I drove it, I just started it up and the check engine light is still on. Should I let it "dry" out a few days or right to the dealer?
Old May 17, 2007 | 08:19 PM
steve8's Avatar
steve8
Holy monsoon batman, you drove it in the rain?
Sorry, couldn't resist.
Old May 17, 2007 | 08:43 PM
Oldvetter's Avatar
Oldvetter
Use the DIC to pull up codes. Do a search for the procedure and list your codes here, you will get help.
Old May 17, 2007 | 09:12 PM
WWK888's Avatar
WWK888
http://www.stengel.net/diccodes.htm
Old May 17, 2007 | 09:17 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Pull some codes and we will be able to tell you what the culprit is!
More than likely got some water in a connection somewhere and the codes should point us in the right direction!
Let us know !
thanks,matt
Old May 17, 2007 | 10:47 PM
jerseycarguy
Thanks for the info, I will pull the codes and see what happened!
Old May 18, 2007 | 07:43 AM
jerseycarguy
It shows code P0171 C
Fuel Trim System Lean Bank 1 ???????
To C5 Engine Light - Help!
