some help on SS letters
Old May 19, 2007 | 08:48 PM
Luv My Vette's Avatar
Luv My Vette
Default some help on SS letters
I have just installed a set of SS letters on the rear of me black vette. They look great but just wondering if anyone had any trouble with the R. The bottom of the R is sharp and too long. It actually pertrudes past the original R of the car. Does any one have some idea of what I can use to solve this problem. I have been thinking of a dremel tool or maybe snips.
Any help would be greatly appreciated....
Old May 19, 2007 | 09:39 PM
krm_wi_C5's Avatar
krm_wi_C5
The R in my set did not fit quite right either, but did work better than yours. I took a few pictures after installation just in case I need to use the warranty. I think I would call the seller and see what they suggest, they will probably send you a new R.
Old May 19, 2007 | 09:50 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I didn't hve any problems with mine (also on a black vette) If you're that worried about it, an option to sending it back could be to use a dremel cutoff wheel as a sander and grind down the edge. If you use it as a cutter you may cut off to much, use the side (not the edge) to slowly take away the excess
otherwise you'll be running around breaking one of th 10 commandments....thall shalt not covette
Old May 19, 2007 | 10:50 PM
96CEC4's Avatar
96CEC4
CI 4-8-9 Veteran
St. Jude Donor '07-'08
Yes, I had the exact same problem with my "R" as well. I might do some work on it as well.
Old May 19, 2007 | 11:39 PM
67weaver's Avatar
67weaver
I just installed mine the other week and the directions said that u should size it up before you put it on and if any modifications needed to be made that it should have been done, it worked ok for mine so I guess this did'nt really help your question but its my .02 cents. I hope all goes well.
Old May 20, 2007 | 08:00 AM
steve8's Avatar
steve8
I asked for, and received a replacement which was better than the first from COH.
Old May 20, 2007 | 08:02 AM
rws.1's Avatar
rws.1
no issues with the R
my biggest challenge was getting the middle part of the E's lined up....
Old May 20, 2007 | 08:31 AM
DeeGee's Avatar
DeeGee
I had exactly the same problem
Be careful if you decide to try the dremel trick. Just the wear of normal use dulled the surface of mine. It's obvious if you look closely.
Old May 20, 2007 | 08:44 AM
stormrider's Avatar
stormrider
Old May 21, 2007 | 04:46 PM
Luv My Vette
How was it getting the old R off ?
To some help on SS letters
